FAQ: Heavy Water Electrolysis Deuterium Source
Andrew Seltzman
Real name: Andrew Seltzman
Re: Heavy Water Electrolysis Deuterium Source
Post by Andrew Seltzman » Sun Feb 27, 2005 11:14 pm
Looks nice. How fast did the D2 penatrate the foil? how thin was the foil?
Andrew Seltzman
www.rtftechnologies.org
Andrew Seltzman
Starfire
Post by Starfire » Sun Mar 06, 2005 7:44 pm
sorry for delay Andrew - I only get on at week ends now. Foil was hot rolled down from a 0.1 mm foil to about 0.005 and Indium soldered on to a SS ring washer then sealed in the plastic tube, but it took forever for the D2 to permeate the foil at 1 bar - the D2O had a bit of Sodium added and was electrolyzed at atmosphere. It would be better with the foil hot and the pressure higher - but how? This was a high school project and on a very small budget.
see Richards post -
viewtopic.php?f=6&t=2220#p11730
and followups
also of interest is Franks ;-
viewtopic.php?f=6&t=2440#p11950
Post by Richard Hull » Thu Jun 16, 2011 4:10 pm
I upgraded this superb thread to a "FAQ".
Now a Simple search of "FAQ" in "titles" only within this forum will bring up this prime discussion on heavy water electrolysis.
