Operation Problem
charlie_mccartney
Real name: Charlie McCartney
Operation Problem
Post by charlie_mccartney » Tue Jun 17, 2014 11:38 pm
I have finished my demo and started running it today. Firstly I have a 12 kv 30 ma NST with a 7.5 amp variac with a metering system made by Richard for my system. On the vacuum side of it I have an Trivac 2.5E connected to a MicroTorr 11-D that is capable to reach <1 microns. Connected to the diffusion pump I have a right angle bellows type high vacuum valve with a 2.75 CF. I am unaware of what my HV feedthrough is rated at and most of my gear can be seen here : viewtopic.php?f=18&t=9241&p=62648#p62648
I have a problem with my system. When I run it the plasma only appears in the range 50-300 microns and I can only apply a max power of .3 kv according to my metering system and when the plasma disappears at <50 microns it says I am not applying any current. Here are some pictures of my best run so far and they are all taken at the exact same moment. Could it be the size of my chamber or my feedthrough? I have no idea, it may be a dumb problem that I have overlooked. Can someone please inform me what is happening and why.
Could I also be placed in the plasma club? Thank you.
HV metering
Vacuum
Plasma
Charlie McCartney
charlie.mccartney1104@gmail.com
charliespersonalproject.weebly.com
Re: Operation Problem
Post by Richard Hull » Wed Jun 18, 2014 8:42 pm
That is a rotten vacuum you have there and the current should be max'd out. and the voltage down to almost nothing. This is normal. You are operating a neon bulb there and not a fusor. You should not try and run a fusor at all until you are well below 100 microns or the neon transformer will buckle. (Too much load and the transformer protects itself)
You have not got the current sensor resistor hooked up correctly for sure.
You do not hook ground directly to the fusor. You hook ground to the transformer case and all the power supply ground points to the case bolt as well as the shielded wire side of the current wire wound resistor board I supplied.
The only wire going to the outer grid or metal shell of the fusor should be the unshielded wire side for the wire wound current resistor board. In this manner, all power supply return current from the fusor must pass through the 1 ohm, high power, current sense resistor to ground and the meter reads this as the current through the fusor.
I think you have shorted out the current resistor by grounding the fusor body/outer grid. This will hurt nothing. It will just not allow the current meter to read.
Again make sure of all your connections. You might disconnect the fusor and take the variac up slowly and you should see the voltage rise. I assume you did all this before ever hooking the fusor to the system. The current meter will not read until you have the fusor connected and drawing current, of course. If the voltage meter doesn't rise then you have wired the voltmeter up wrong as well.
charlie_mccartney
Post by charlie_mccartney » Thu Jun 19, 2014 12:17 am
I have hooked up the system like you told me to in the video, with the outer grid going to the floating nut and the ground wire from the plug going to the NST, with the resistor in-between them. The problem was my poorly made inner grid which was I made in a rush, I will fix it and report with information on my run, thank you for the information.
Charlie McCartney
Post by Richard Hull » Thu Jun 19, 2014 9:38 pm
Does the high voltage read OK without the fusor hooked up? Make sure it does. It should.
charlie_mccartney
Post by charlie_mccartney » Thu Jun 19, 2014 11:49 pm
How do I test it?
Charlie McCartney
Post by Rich Feldman » Fri Jun 20, 2014 12:48 am
Hi Charlie.
Can you find a local mentor who can help you
to understand the basics of voltage sources, electrical loads,
current in wires, and metering circuits?
What Richard wants to see is a measurement
when your power supply's negative output is disconnected from fusor,
but still connected to the high voltage metering circuit.
Do not change the positive (ground side) connections between power supply, fusor, and metering circuits (including the current sense resistor).
If in doubt, draw and post an accurate schematic diagram of how the electrical parts are connected.
https://learn.sparkfun.com/tutorials/vo ... viders/all
charlie_mccartney
Post by charlie_mccartney » Fri Jun 20, 2014 4:03 am
No, after almost a year of searching I cannot find a mentor.
Charlie McCartney
charlie_mccartney
Post by charlie_mccartney » Sat Jun 21, 2014 7:01 pm
When the NST is on and hooked up to the metering system it reads .3 kv
Charlie McCartney
charlie_mccartney
I am using a 12 kv 30 ma NST
Charlie McCartney
Post by Rich Feldman » Sat Jun 21, 2014 9:52 pm
charlie_mccartney wrote:When the NST is on and hooked up to the metering system it reads .3 kv
Something is very wrong, and dialog here is not a good way to find out what.
Part of the problem is that you don't seem to know enough about electricity to ask informed questions.
Set the fusor aside for a while, and pay attention to your power supply and metering gear.
Want to take some time to learn the basics, or would you rather skip that and move ahead with your fusor?
Assuming the former, the Internet makes self-teaching easier than it used to be.
Can you light up LEDs or light bulbs, or run a motor, with a battery?
Can you measure the voltage _and_ the current in those circuits, and understand the difference?
If the answer is no, here's one place to start reading: https://learn.sparkfun.com/tutorials/wh ... uit-basics
Regarding your immediate source of frustration, you can test the NST by attempting to draw arcs. Electrically attach one end of an insulated wire to the transformer case -- there's probably a screw for that purpose. Momentarily touch the other end to a HV output terminal, or to the junction of your rectifier diodes. Pull it away and see what happens. You could also try lighting a fluorescent lamp (be sure to bypass any built-in ballast) between any of those HV nodes and the transformer case.
For online support on this forum, it would help to see a schematic diagram of what seems not to work. Or a picture that shows all the wires. You don't need to show what's inside the box, just what you have connected outside the box. You can't usually expect helpers to spend more time answering than you spend asking. Good luck!
