Thermal imaging of fusor grid / plasma
Andrew Seltzman
Real name: Andrew Seltzman
Re: Thermal imaging of fusor grid / plasma
Post by Andrew Seltzman » Thu Jul 17, 2014 6:37 am
Beam expander assembly to reduce beam to size of optical detector
Test setup, soldering iron as heat source collimated through germanium lens
Shadow viewed on detector
Andrew Seltzman
www.rtftechnologies.org
Andrew Seltzman
Post by Andrew Seltzman » Sat Jul 19, 2014 8:16 pm
Direct imaging of expanded 10.6um beam from CO2 laser with thermal imager.
Synrad H48-1 with a 9x beam expander that has an internal adjustable iris to prevent reflection of the over expanded beam off the internal walls of the lens tube that cause a halo around the primary beam. Imaged with a thermal eye 2500AS
Before iris was added
After iris was added
Video of adjusting iris
http://youtu.be/5j9_Yv9_eOM
Germanium rear coupler mirror 99.5% reflective, 0.5% transmissive, used as a 200X power attenuator
Coupler mounted on front of thermal imager beam expander
Laser setup
Laser modulation profile, 6% duty cycle, 1khz square wave, for further reduction in laser power
Bench test imaging of shadow in beam cast by soldering iron tip
Captured image of shadow
Video of moving metal tip through imaging beam
http://youtu.be/x_UALp30oOA
Andrew Seltzman
Andrew Seltzman
Post by Andrew Seltzman » Sat Jul 19, 2014 9:15 pm
Imaging setup running with fusor with no plasma.
Laser setup with fusor
Beam aligned with core input window
Thermal imager viewing beam at output window
Shadow from central grid
Videos of viewing the grid while repositioning the thermal imager
http://youtu.be/ZD-UnhpNOC4
http://youtu.be/N12B16Lp1gw
More pictures at
http://www.rtftechnologies.org/physics/ ... ometer.htm
Andrew Seltzman
Andrew Seltzman
Post by Andrew Seltzman » Thu Jul 31, 2014 6:13 am
Preliminary testing of the laser system with plasma.
Setup of fusor with quad ion injector system, vacuum system, and CO2 laser probe
Quad injector power supply, 5kV, 3ma per channel for anode layer ion sources
Ion injector power cables
Starmode with ion injectors
Grid with coolant flow off
grid with coolant flow on
Laser density probe of plasma
Overall the laser probe observed nothing, which was expected at this point since the grid power supply is very under powered (5ma max) and can not bring the plasma density above cutoff at 10.6um. A capacitive pulsed system for the grid, and a interferometer setup for the laser are in progress.
The ion injectors work perfectly, however since they can flood the the entire chamber with plasma, they tend to over power the grid power supply when even one is running at maximum output. One interesting observation, by varying the ion injector power individually, the center of the star can be pushed around the inside of the center grid.
Andrew Seltzman
Post by Richard Hull » Thu Jul 31, 2014 3:21 pm
Andrew, This is some great data collection effort on your part. I am sure most everyone follows this with great interest. As this progresses and when you feel you might be able to issue a final summary report of your work, please do so. Some of your data already given is most intriguing.
Andrew Seltzman
Post by Andrew Seltzman » Sat Aug 30, 2014 2:53 am
Plasma at 5mTorr
Videos of thermal imaging fusor interior, some at 320x240 resolution, turning on and off grid coolant flow
http://www.youtube.com/watch?v=8suOQDY9668
http://www.youtube.com/watch?v=lxMEJhGmrmA
http://www.youtube.com/watch?v=UUihlkrJeQw
http://www.youtube.com/watch?v=8DfPozHL37A
Interferometer beam splitter mount
Grid viewed through interferometer beam splitter
Interferometer reference beam arm
Turning mirrors
All updates so far
Andrew Seltzman
Andrew Seltzman
Post by Andrew Seltzman » Fri Sep 19, 2014 5:48 am
Construction of the grid mounted ion collector to measure the distribution of ions hitting the grid surface based on temperature rise of each segment is complete.
Copper disk with one segment machined
Machining down center thickness to 0.2mm
Machining ion collector
https://www.youtube.com/watch?v=ZUyIb7z ... e=youtu.be
Ion collector segments
Ion collector mounted on grid
Ion collector mounted on grid, grid installed in reactor
Andrew Seltzman
Andrew Seltzman
Post by Andrew Seltzman » Fri Oct 03, 2014 3:56 am
Report on findings so far
seltzman_us-japan-2014.pdf
(2.58 MiB) Downloaded 329 times
Andrew Seltzman
Andrew Robinson
Real name: Andrew Robinson
Post by Andrew Robinson » Mon Oct 06, 2014 5:39 pm
Impeccable work Andrew. I am following your efforts with great interest.
Ben_Barnett
Real name: Ben Barnett
Post by Ben_Barnett » Thu Jan 24, 2019 8:34 pm
A 1 inch (25.4 mm) Zinc Selenide window costs ~$300 USD, and the thermal camera comes up around $500.
Is there a way to do thermal imaging of the fusor grid (to determine plasma/grid temperatures) for under $300 - $400?
Or maybe someone can point me in a different direction.
We are aiming to vary the grid geometry in the fusor, and take measurements to compare the effects of the different geometries. Aside from input voltage, current, and chamber pressure, if possible a measurement of the plasma temperature would be great if for a reasonable price.
