Component Insulation from Vacuum Chamber
Excuse my niavety, but why are some components (vacuum pumps, gauges, gas lines) insulated on some images of fusors I have seen, but not on others?
Re: Component Insulation from Vacuum Chamber
Insulation is not normally required on anything attached to the fusor except the HV terminal input line or anything associated with the inner grid (cathode). The fusor shell or body must be at ground potential. Any insulation is accidental or, if deliberate, is not necessary.
That makes sense, but what about a turbo pump? It seems like that may cause a problem. Maybe I am mistaking what is just an extension for insulation.
Do you want to point to which images of kit you think shows insulated/uninsulated components? Usually, the interconnections between the parts are metallic, and everything ends up grounded one way or the other. I've not seen anyone here use plastic screws!?
I don't know if I can find them again, they popped up during an obscure google image search for some part I was looking at. I know I saw this though: http://www.lesker.com/newweb/feedthroug ... 8V2376.jpg
If you want an electrically isolated chamber, then you can definitely make an isolated chamber if you want! My first design was glass and tufnol (bakelite) because I specifically wanted 'insulated', but it is still dead tricky to manage that scenario because you will still get discharges down your vacuum lines (to your grounded vacuum kit), unless you are really careful to control the 'pressure x distance' thing.
Other than that 'non-fusor' oddity - and also Steven Sesselmann's accelerator column with an end-chamber held to a big low potential - I don't recall seeing any examples of electrically isolated/ungrounded fusor chambers here.
O.K., thanks. I think that settles it.
