My Fusor.
TannerOates
Real name: Tanner Oates
My Fusor.
Post by TannerOates » Sat Sep 24, 2011 7:08 am
nearly complete but how do i transform AC from a neon sign transformer to DC- Any critiques or questions of my design?
Photo on 2011-09-24 at 01.00.jpg (129.73 KiB) Viewed 1373 times
Photo on 2011-09-24 at 01.05.jpg (101.06 KiB) Viewed 1373 times
Re: My Fusor.
Post by Chris Bradley » Sat Sep 24, 2011 8:04 am
Is the braided hose 'vacuum-capable'?
TannerOates
Re: My Fusor.
Post by TannerOates » Sat Sep 24, 2011 3:30 pm
Yes very.
Re: My Fusor.
Post by Chris Bradley » Sat Sep 24, 2011 5:10 pm
Looks like you're all set, then.
That looks like a big [read; expensive to replace] viewport that you might want to protect with a sheet of some sacraficial glass inside the chamber, if you've not already done so (can't see from the pic).
Carl Willis
Real name: Carl Willis
Re: My Fusor.
Post by Carl Willis » Sat Sep 24, 2011 7:24 pm
You've got a nice chamber, Tanner. You'll be able to go far with it.
About the NST-based high voltage supply, the only good advice is to use the forum search feature and read the archives. This path is commonly followed and extensively documented. Your question about rectifying the output has already been answered. With rare exception, the voltage and power available are not sufficient to generate detectable fusion reactions, but this kind of power supply is an accessible stepping stone or an entirely adequate supply for a "demo" fusor. Consider recruiting a local mentor with hands-on HV experience if this is a weak area for you.
Carl Willis
TEL: +1-505-412-3277
