Question about radiation shielding of reactors
KramerPowerHouse
Post by KramerPowerHouse » Tue Aug 02, 2011 8:28 pm
I hear that radiation sickness is quite Deadly in certain cases, so in the hope of preventing this
What has been the prefered method? How did you test it's effectiveness?
Thanks for sharing your valuable knowledge.
Matthew Kramer
California
Re: Question about radiation shielding of reactors
Post by Chris Bradley » Tue Aug 02, 2011 8:39 pm
If you post up the neutron measurements you mentioned in your introduction, I will try to, or I'm sure someone will, direct you to the appropriate thread in this forum that will contain the right info for you, according to the reproducibility and measurability of what your data shows.
Wilfried Heil
Post by Wilfried Heil » Tue Aug 02, 2011 8:54 pm
It'll be a long way to go before the fusor becomes a radiation problem.
The only real danger that I see is the electrical shock hazard, or maybe accidentally
touching the shell while it's still hot.
Carl Willis
Real name: Carl Willis
Post by Carl Willis » Tue Aug 02, 2011 8:54 pm
Nobody in this hobby legitimately faces the issue of acute radiation sickness. It's a non-issue. If you are under the impression this is an issue for what you're involved with, there's a 99.9+% chance you're just misinformed, and a very small chance you need to hire a qualified RSO and establish a state-licensed radiation safety program with various engineered and administrative controls.
As far as real-world radiation protection goes, the chief safety concern from homebrew fusion apparatus has historically been x-rays. We have what is called a "Neutron and Radiation Detection" forum where this problem and its mitigation have been discussed regularly and in much detail over the past ten years. I know it is hard to find this information, read it, and comprehend it, but that's my suggestion for getting started.
Carl Willis
TEL: +1-505-412-3277
Edward Miller
Real name: Edward Miller
Post by Edward Miller » Wed Aug 03, 2011 2:45 am
SPF 50!
Sorry I couldn't help myself. Minute per minute unprotected Sun tanning will cause greater injury.
Post by John Futter » Wed Aug 03, 2011 6:34 am
Heres a circuit diagram of a radiation protection circuit
quite neat really
Post by Chris Bradley » Wed Aug 03, 2011 7:19 am
John, I don't think you are really taking the issue of radiation detection seriously. How do you expect anyone to follow that diagram without a part number for the bat?
Dustin
Post by Dustin » Wed Aug 03, 2011 8:36 pm
That power supply at the top is unreal.
Can I use superglue instead of hot glue?
Steve.
George Dowell
Post by George Dowell » Thu Aug 04, 2011 3:16 pm
Whats the part number on that PPP transistor?
George Dowell
Quartinus
Post by Quartinus » Sat Aug 06, 2011 7:20 am
Credit where credit is due: https://www.xkcd.com/730/
