Fusor cleaning time!
Tman
Post by Tman » Sat Aug 19, 2006 5:59 pm
I am getting ready to give everything an acetone cleaning. Then I'll flush my recently aquired 3" diffusion pump with some 91% isopropyl, and heat it a while to evaporate any water.
After cleaning I just have to wait for the bubble detectors I ordered to arrive. I dont want to bother injecting D2 unless I have at least one neutron detector around.
My He3 detector is getting close.
-Thiago Olson
pics8-19-06 022 small.jpg (32.11 KiB) Viewed 640 times
Re: Fusor cleaning time!
Post by Richard Hull » Mon Aug 21, 2006 1:19 pm
Good luck on cleansing your system. It is a good idea to start fusion experiments in a clean atmosphere, no matter how reduced that atmosphere is.
DaveC
Post by DaveC » Mon Aug 21, 2006 6:44 pm
Acetone is very volatile, but it is a good idea after the liquid solvent has evaporated, to apply a heat gun (or a hair dryer) to each part until it is to hot to hold in your (gloved) hand. This will dramatically shorten the initial pumpdown, and help keep your pump oils (assuming a mechanical roughing pump and diffusion pump) clean.
A healthy amount of gas ballast in the roughing pump for the first half hr is also a good idea.
System parts look good. You are ready to begin.
