Quick update on construction
apollo
Post by apollo »
Hello everybody
Yes, I'm still alive. I've been away for a long time working on several projects (fusor and Tesla coil, mostly). Thanks to the help of a professor at Union college in Schenectady, my Robinair issue will soon be solved. By simply sticking a hose over my 1/2" NPT fitting, he was able to get the pressure down low enough that a poissor was formed. Hurray!
Still, any help finding what thread is on the Robinair pump would be greatly appreciated (that is, AFTER the tee with the 1/2" Acme and 1/4" MFL fitting is removed!). If not, we'll have to make a part (or get a better pump).
apollo
Re: Quick update on construction
Post by apollo »
Today I installed an accurate gauge and I'm right at 1000 microns. I should be able to get back down to well under 100 if I can ever figure out what this fitting is.
Edward Miller
Real name: Edward Miller
Post by Edward Miller »
There's a very good article on Swagelok's site that goes over 10 different types of pipe connections.
http://www.swagelok.com/downloads/webca ... itting.pdf
apollo
Post by apollo »
Thanks edmo. I was wondering if you had any idea what the bottom fitting could be:
http://www.usatoolwarehouse.com/Merchan ... -15495.gif
After reading over all of them, it doesn't seem to fit any really well since it's not flared at the bottom. Any ideas?
Edward Miller
It looks like the SAE Straight-thread fitting shown in the picture. The seal is provided by the rubber material, not by the threads. I would say that your best bet is to look on eBay for Swagelok parts there are many standard sizes, either Compression, NPT, or VCR fittings will work. I prefer 1/4 Compression fittings, there's a good seal, I can cut the exact length of pipe I need, and I can reuse the ends without a new washer (like in VCR) (1/8" compression also works). NPT is okay for some of the other interconnections (like to the regulator, vacuum, etc)...
