I thought that might have been the problem.
My uncle has a BIG pump used to create the vaccum between the two insulating layers in liquid nitrogen tanks ... would that work?
Better Pump
Re: Better Pump
Keep in mind the geometry of your chamber. It's a fishbowl, so a good vacuum from the inside will distribute its forces on the glass unevenly due to differences in glass thickness at certain points. This could cause the chamber to implode. Who made the pump and what model number is it?
Re: Better Pump
I don't know anything specific about the pump. My uncle just mentioned offhand once that he had a vacuum pump used to evacuate the space in liquid nitrogen tanks. It probably doesn't even work--last time I saw it it was just a rusty heap in his yard.
Re: Better Pump
Anthony...
Your uncle's pump, even if rusty on the outside, could well be useable if it still has oil inside. I would suggest getting it and start to clean it up... if.... you can turn the pulley reasonably easily by hand. Getting acquainted with the parts and pieces, vacuum pump oils and fittings , hoses and such... is a good summer pastime.
You can get lots of help from all the experienced ones here if things get confusing..
Dave Cooper.
Dave Cooper.
