In reference to Implosion problems, Just remember that high vacuum is only about 14.7 psi relative to sea level., I find it funny when safety is replaced with a glass jar not rated for vacuum.
In your system Colin you say you are using a stainless 2mm chamber.. that should suit you fine, the only problem you might run into is tig welding the vacuum fittings. you might burn through the steel depending on the skill of the welder. and this could lead to a minor leak. nothing that a little elbo greese cant fix. Good luck with construction.
Craig Wallace
High Vacuum
Jump to
- Announcements
- ↳ Announcements and Site Administration Topics
- ↳ The Fusioneers
- Start Here
- ↳ Frequently Asked Questions (FAQs)
- ↳ Please Introduce Yourself
- ↳ New User Chat Area
- The WaterStar Project: Finding the Trailhead
- ↳ Philo T Farnsworth Archive
- Images and long term fusor.net contributors
- ↳ Images du Jour
- ↳ Compilations of long term fusor.net technical contributors
- Theory
- ↳ Fusor and/or General Fusion Theory (& FAQs)
- ↳ FAQs: Fusion and Fusor Theory
- ↳ Other Forms of Fusion - Theory, Construction, Discussion, URLs
- Construction / Technical Do not post simple questions here. Use the New User Chat area
- ↳ Fusor Construction & Operation (& FAQs)
- ↳ FAQs: Fusor Construction & Operation
- ↳ Vacuum Technology (& FAQs)
- ↳ FAQs: Vacuum Technology
- ↳ High Voltage - Fusor Input Power (& FAQs)
- ↳ FAQs: High Voltage
- ↳ Neutrons, Radiation, and Detection (& FAQs)
- ↳ FAQs: Neutron - Radiation Detection
- ↳ Ion Gun Design and Construction (& FAQs)
- ↳ FAQs: Ion Gun Design and Construction
- ↳ Control and Instrumentation Hardware and Software
- ↳ Advanced Technical Discussion Area
- Miscellaneous
- ↳ Fusion --- Past, Present, and Future
- ↳ Interesting Links
- ↳ Files
- ↳ Books & References
- The Trading Post
- ↳ Primary Sources for Fusor Related Items
- ↳ Items For Sale
- ↳ Items wanted
- The early beginnings of fusor.net
- ↳ Songs Archive
- ↳ Intranets Archive
