Mass flow controller question
brett_kvo
Real name: Brett Kvo
Re: Mass flow controller question
Post by brett_kvo »
Thanks for the advice all.
RIchard--any idea how you might digitally control one of those leak valves? I appreciate the precision and repeatability of it, but we're attempting full computer controls and the MFC checks the box.
Easy if you have the skills. Remove the knob and attach a high torque stepper motor. Count steps from off to various calibrated running gas points and interpolate between step counts to create an array that can step to numeric gas pressure to needed step counts. Or simply avoid this and have a forward and reverse rocker switch to drive the motor in or out. Finally and most desirable is that the motor stepper could be linked to the pressure gauge in software to cause it to seek a punched in pressure and hold it there in a virtual servo loop. Many ways to skin this cat once a stepper is attached.
brett_kvo
Post by brett_kvo »
Great. Thank you. That's what I had in mind as well. I like this direction over the MFC. :)
Bob Reite
Real name: Bob Reite
Post by Bob Reite »
I use a 0-10 SCCM mass flow controller. I set the flow rate with a 10 turn pot. For my chamber, I usually operate between 3-5 SCCM.
Artem Artemov
Real name: Artem Artemov
Post by Artem Artemov »
I had an idea to connect a stepper motor to my needle valve, but this is archaic. You need an motor, a driver, a controller, calibration, and dance with drum. I think it's easier to use mfc with an analog control signal. But if you are serious guys, you can use mfs and vacuum gauge with devicenet, combining everything into one network. Many phillips vacuum gauges have a devicenet. Then you will need to buy an mfc with this function for perspective. You can fully automate everything.
In the future, I want to connect everything through this network. I bought vacuum gauge with devicenet, but they can be used without using this network, the gauge have screens. But such gauge with a screen are expensive(
Ps You can also use the MFC and needle valve at the same time. You give the signal to fully open the mfc and work manually with the valve wheel.
Liam David
Real name: Liam David
Post by Liam David »
The Devicenet connector pinouts include can_h and can_l. If I'm not mistaken, you might be able to communicate with the gauge using the standard CAN bus. There are Arduino shields/breakouts that would make this pretty easy. I have a convectron gauge identical to Artem's, but haven't investigated whether this is possible and am not familiar with the standards, so take it as is.
brett_kvo
Post by brett_kvo »
Hey Bob, could you tell me the exact make/model of your MFC? Just curious what's worked well for you.
We managed to find an old precision leak valve laying around, so I think we may go that route for version 1.0 (manual control) of our reactor. I think we'll pursue either an MFC or a stepper-motor driven leak valve moving forward.
Thank you all for your thoughtful responses. This information just can't be readily found anywhere else on the internet.
You are right Brett. We have years of accumulated knowledge here and lots of folks who have done the same thing in many different ways, successfully. You came to the right place. Thanks for the accolades to all of us and this site.
Bob Reite
Post by Bob Reite »
Mine is a Sierra Instrumentation "Side track III" "cust code I-458 Range 0-10 SCCM Orifice .010" Gas H2. I found it on Ebay. Any MFC that can be set for 0-10 SCCM will do.
brett_kvo
Post by brett_kvo »
Thanks Bob! Much appreciated. :)
russssellcrow
Real name: Russell Crow
Post by russssellcrow »
We use a STEC SEC-7440M mass flow controller. It is older (Analog), rated at 200 SCCM, and calibrated in Argon.
We are able to control the chamber pressure in increments of 1 micron, from 10-200 microns. These beat the heck out of trying to balance pressure using a needle valve, the control is so much finer.
