NEW Fusor V build under way.
- Bob Reite
- Real name: Bob Reite
Re: NEW Fusor V build under way.
I'm using the REM Ball these days exclusively when I operate my fusor as I trust the calibration and I don't have an infinite budget to buy bubble detectors every six to nine months.
Another great Silver activation day and high point in the new fusor V saga. The system secret is speed and playing "beat the temperature clock". I ran the system for a total of 20 minutes today from dead off to highest activation level and with numbers not yet seen in fusor V. The data is in the enclosed captured Xcel graph. (98,288 CPM)! Images are captioned.
Note: four background runs of 10 minutes each yields 240 data points indicated a mean count of 13 and a sigma of 3.6. Still, to my mind, it is not a great statistical result to hang one's hat on. ( very gamma noisy lab) The detector will not count gammas....Maybe 1 in 200. It is detecting, as I have noted, photo electrons and some limited Compton electron scattering from the extant gamma field, impinging on the silver and tube walls
Addendum: In the wee hours of the 22nd, I went out and activated again. The new graph shows far greater activation due to similar neutron numbers, but I placed a single layer thickness .003" roll or cylinder of silver around the tube as a silver tubulation over its sensitive volume. (much better)
As I continue to run fusor V every day or every other day, my viewport is virtually opaque to visible light. NO color. NO central star. Only the IR seen from the glowing grid is seen on the monitor.
I have about 4 other replacement viewports. I wonder if it is worth replacing it for the HEAS October crowd? If I open the fusor it will take a week of daily runs to work it back to superior operation. I assume everyone has seen the pretty color stars, etc., and a clean color image is of no great interest. What I will show is the silver activation and post-run count as well as creating an excel graph as all watch who are interested.
I am also considering removing my 23 inch long 3He tube and replacing it with a 12" active length 4ATM Reuter-Stokes, 3He tube. I have the cps/nv manufacturer figure for this tube and it is 40. this reduction will make for a lower count per run, but allow for less possibility of pile-up and for more flux if I can get there. It should also be more suited to the moderator that I have and, in all probability, indicate the same flux under the same max conditions as the big tube. (lower count and lower counting efficiency means the same flux) I will probably do this after HEAS.
I am also going to mount that 5" BC720 on the PMT. In theory the count from this proton recoil counter should be 5% or even less than any 3He count at ~0.1% count efficiency. I will probably calibrate this system using the well calculated 3He data collected co-jointly on several fusor V runs.
- Bob Reite
That's the viewport from Fusor IV correct? Must have a lot of hours on it. Mine is getting a bit hard to see through, I have a couple of new ones, I originally bought them on Ebay as a "must take all three" deal.
No! Actually it has only been in use as a brand new window as of the first post in this thread, 7/10/20.
Look at the colorful, full image in the post of 7/11. I have been driving this iteration very hard. Again, only the fact that the video camera is sensitive in the IR that I see only the snow white, heated grid, floating in a totally ink black void.
- Bob Reite
The IR totally overwhelms the camera. I snapped my photo by turning off the HV, just long enough for the grid to cool, then starting it up and snapping the photo before the grid had a chance to heat up again.
The window is 100% opaque to any visible light whatsoever, period! It might as well be made of stainless steel. It is not a #10 density filter it is worse than that. Intense IR is all that will penetrate. A the windo is of no real use, I will leave this sleeping dog lie until after the HEAS gathering. All who attend will see what I mean. I will then swap the window out after HEAS.
- Bob Reite
I'll have to see it for myself. Hard to believe that you turned the window black in such a short time. Maybe your grid is closer to the window than my setup.
Another record run today. I attached the image of silver activation graph.
I hit 120,736 cpm on the counter. This results in a TIER of 137,000 n/s
The grid is 1 inch in diameter in the center of a 6" diameter sphere. window is offset from the sphere by .75 inches. This makes the outside grid wire nearest the window 3.25-inches from the glass.
I plan on detailed runs for all fusioneers attending HEAS in a week or so. Now I can start from nothing on to finished activation in under 30 minutes.
- Neutron Activation AG 9-23-20.JPG (91.08 KiB) Viewed 7639 times
- Jim Kovalchick
That TIER number seems low for the good activation you are doing.
True, it does but that is what I get from the data sheet for the 3He tube I am using. I did an update on calculating this in the FAQ on Calibrating neutron counters just a few days ago. You should have seen it. It is near the end of the pdf. It begins at the addendum.
- Calibration of neutron counters.pdf
- (189.25 KiB) Downloaded 236 times
I made some really bad assumptions related to the counting efficiency 59 cps/nv from 63cps/nv. I was also off on the average distance from the 3He tube to the net source of neutrons, from 18cm to corrected to 24cm. These adjustments considerably corrected the TIER and my constant of multiplication. The TIER is not 137,000 n/s, but is now 248,717 n/s. Likewise the multiplication factor is no longer 1.135 but is now 2.06 times the cpm rate.
Thanks Jim for pushing me to really question my numbers. I can do a detailed presentation at HEAS on the large white board as to the adjustments.
All the PDF files are now fully corrected. You might reload them if you want the math corrections. They are the same, so just reload the original post's PDF.
Always refining by closer examination of the parameters.
- Bob Reite
I really didn't think that you could successfully activate silver with only 137, 000 n/s. 248,717 is more realistic, but I still thought that you had to be near the mega mark to do activation.
I think a detailed view of your TIER calculation adjustment at HEAS would be great, definitely something I would enjoy to see.
Aidan
Aidan
You will see the complete derivation update on my white board. I put it up today and ran through a verbal explanation for practice to an empty lab. Talking to myself again....tsk...tsk.
Unfortunately, on rechecking the cps/nv on the spec sheet, the figure of 63 is given with the stated accuracy of +/-20%?! So, it could be either 198640 or 297360 or anywhere in between the computed 248,717n/s.
It is to be remembered that a 3He tube is a proportional counter and once out of the manufacturers hands, it can be biased anywhere from 1500-2000 volts and be in spec, this can affect pulse height and the proportional slope. In addition, the windowing can benefit or limit the neutron count. I think they took this into consideration.
I am going to pull out the digital o'scope and tune this thing up a bit from the preamp on to the main amp. Again, and this has been said by me many times.... There is no absolute neutron counting system. There is absolute precision to 1% or better in a fixed neutron counting system to relative quantitative improvement or degradation between runs.
- Jim Kovalchick
I hope to discuss this with you in greater detail at HEAS next week, but I think your detector geometry makes trying to calculate the TIER rather complicated. Your detector does not intersect a uniform neutron field. Point source calculation does not work.
I am also curious about your hdpe thickness. There is an optimum thickness, but that is affected by geometry too. As I recall, Carl Willis showed that for activation, about 1.5" was optimum. Any thicker lowered counts. I dont know what the predominant factor was but I think its a combination of thicker moving the sample point further from the source and experiencing moderator absorption of the neutrons once they made it to thermal. Have you tried different hdpe widths?
Jim K
Jim K
- Real name: Jon Rosenstiel
I've found that 1 to 1.75-inches of HPDE moderator works well for silver activation. (Reflector thickness of 4")
I think on paper 1" would not be enough, but I suspect the increased neutron flux more than makes up for it. (Inverse square law)
Edit: And we also need to take into account silver's large cross section for resonance neutrons.
JonR
JonR
I have taken most all of the non-uniform moderator into account. Again, you will see it all. I detailed with precision my moderator in the neutron radiation forum.
viewtopic.php?f=13&t=13553
If one follows, assiduously, Mark Rowley's postings he is using a similar dimensioned moderator and is doing great! An image is in the above thread of his setup.
The old water moderator with this same tube and circuitry never recorded much over 60,000 cpm with Fusor IV. I just counted 133,757 CPM yesterday. (298,000 TIER by the new calcs) Better moderation in this setup with similar moderator geometry (offset vertically in fusor IV, offset horizontally in fusor V).
I am fully aware of all the possible non-linearities that can creep into this related to geometry, neutron loss in an overly thick moderator. I have tried to make adjustments, though still less than precise and less than ideal with the attendant +/-20% related to the tube itself.
Current graph below
Current graph below
- Real name: Cai Arcos
Richard:
Would you consider posting the derivation of the calibration factor here after HEAS? I'm really interested in it, but unable to attend (I have, in fact, never travelled outside Europe, and only once with in).
I will pull it together after the HEAS as I wish to have other's inputs to refine and refresh my first pass at deep thoughts related to the 3He system. It all seemed so simple with the tube specs to mathematically figure the flux. Geometry is a complicating factor that fouls a simple calculating approach. Based on my new approach I managed to chase the cps/nv from 63 to 54 and expand the distance to the sensitive neutron counting region or zone. (enlarge the TIER sphere a bit). This has resulted in a 3X TIER result from just a bit over 100k counts to nearly 300k counts. See the updated PDF in the first posting...updated to 9/25/20 results.
Cai, you are much like me. I hate to travel. Unfortunately the Air Force flew me all over hell's half acre during my 4 year tour in the Vietnam war era. I was in England, the Netherlands, Vietnam, Japan and Thailand outside the US. In the States, I have been in Alaska, Colorado, Utah, New Mexico, Kentucky, West Virginia, North Carolina, Florida, Mississippi, New York, Maryland, Louisiana, Georgia, Pennsylvania and Delaware. I still have never been in 35 of our 50 states. My favorites, outside of my home state of Virginia, would be Colorado and Utah due to their grandeur in variegated scenery and other attractions that drew me there.
I do tend to dislike travel. Home is called home for a reason! Your comment about never visiting 35 states made an European like me realize how huge and vast the USA really is. You could in fact visit almost all climates without changing country.
The calculation of flux in a non uniform scenario seems to me, unless you assumed all neutron flow was thermalized and just diffused into the detector aftet, would require some notable mathematical/geometrical skills. I found the FAQs about simulation to be a lot more instantaneous. If I recall correctly, Experimental Nuclear Physics by Mukhin, had some detailed explanations. Will check when I got time and if so, post them here.
EDIT: Here are 9 pages, the more "practical" ones I could find of a notable section that talks about moderation. I'm sorry these are photos and not scans, but I'm fearful of damaging the spine of the book (bough it "new" at a scientific library which only has original and reprints of MIR editions, and I've made every effort to keep them intact). It is a really great book that I would recommed to anyone here. Also note his remark about light moderators (only a very rough estimation can be given, and the exact value should be determined experimentally) after spending several pages discussing possible models! Finally, it is also important to me that (at least for what I've gathered), the only "easy" way to estimate the flux of neutrons in a semi quantitave manner is through diffusion.
We come back to the old saw. Exact neutron numbers based on all the mathematical gyrations is, in effect only a close approximation, assuming the moderators covered in the 9 pages. HDPE is another medium altogether! Geometry in this case is also critical. Theoretical machinations are great under precise, controlled and unchanging input parameters There are no neutron beams from a fusor. Detectors are macroscopic with considerable extent.
Most of the more recent postings here are a crude attempt to get a feel for the TIER for fusor V and avoid the necessity of spending $300 plus for a 6 month life span bubble detector that is carefully binned to a precise number of bubbles per mrem of fast neutrons.
- Bob Reite
Hopefully my REM ball will let you know to within 20% of what Fusor V is actually putting out. If someone else is bringing a calibrated neutron detector, the more the merrier!
Sad news... I am once again going to make up a new fusor V as fusor V "C". the saga of fusor V "A" was short and not sweet.
Fusor V "B", the current model, was going great as witnessed during HEAS during October. The real work appeared in the neutron forum with the silver activation reports and calibrations. Unfortunately, over the last three runs the old insulator arced externally. I think I know why. I have started to run the fan over the fusor to increase the output via external cooling and it has done marvelously as my recent reports on activation show. Note: All of the relevant information between the last post by Bob Reite and this one is to be found in the large number of posts in the URL below.
viewtopic.php?f=13&t=13568
The URL above really speaks to the best work done by Fusor V "B"! I consider this my best work with fusor V thus far.
The reason for yet another or third iteration of fusor V
I had an external arc condition 6 days ago. It carbonized, (blackened the silicone HV putty). I picked out the little area of putty and replaced it with fresh putty. The next day another run reached 41 kv and the external arc re-occurred. This shook me considerably. What changed? The fusor has worked flawlessly from July onward! I suddenly realized it was the fan! It seemed the fan blowing over the tilted fusor, carried the stream of hot air over the insulator. Hot air in a moving stream will reduce the breakdown in air. My old days in Tesla coiling taught me that lesson well.
I repaired the fusor putty once again and again it broke down at 42kv. That was yet another straw to break the camel's back and my patience!! Over the last three days I have pondered deeply and have decided a fusor V "C' is in order. All here will remember the A,B, episodes and now will suffer a C episode. I will, once again upon completion of fusor V "C", in future, refer to it as simply fusor V. Hopefully, a long term fusor V will some improvements!
I have just secured and purchased a 6 way 6" conflat cross. I want more interior room than the old "A" cross. I am sure the 4" open area In "C" will be more kind than the 1.5" area in "A"
So, I am signing off and will be closing out this post's thread to start yet another new fusor posting around the new fusor embodiment in the near future. The one saving grace is that in spite of the three external arcs, unlike Fusor V "A" 7 internal arcings, the Turbo and controller survived the EMP and RFI bursts. Whew.... 2020 has just been a year for the history books in many ways.
