Demo Fusor Progress
Jim Enright
Real name: Jim Enright
Demo Fusor Progress
Post by Jim Enright »
Hello everyone! I hope I'm posting to the proper forum, but if not, please let me know!
As some of you may recall from previous posts, I am a high school special education and STEM teacher, as well as an advisor for the High Energy Physics club at the high school where I work. We considered several demo fusors but decided on the Make Magazine version for now due to relative ease of construction and cost (I am funding the club myself). Although this particular demo fusor is not even close to the scope of a research grade demo fusor, I wanted to take small steps in the process so that the science of the process would not be lost. I also felt it important that we research IEC and build a prototype of the demo fusor to understand the construction and how it would work. The pictures are of the finished prototype. The vacuum pump and OBIT are only for a visual for the students so they could see how it all connected and was powered. The gauge at the top is also only for visual purposes - it is actually a gauge from an old welding unit! For the actual unit, we will be using a 1-HP, 2-stage vacuum pump, and a 15kV NST connected to a 140V variac. The inner grid in the prototype is just soldered paper clips! The actual inner grid (in the 3rd picture) is 1mm stainless steel TIG welded. We will begin construction of the actual demo fusor after Thanksgiving break. Our goal is to eventually move to a stainless steel cross to house the grid.
The primary goal of this project is for the students in the club to understand how IEC works to produce fusion. Being a STEM project, I felt it important for the students to first become familiar with the components, evaluate the design plans, then build a prototype. We have access to a full welding and woodworking shop in our school so all components are constructed by students. Once the actual demo fusor is built, we will consult with an electrician regarding safety (he is a certified electrician with children in our school district so he is always willing to help us, as he did when we built CRT's from glass bottles this past Spring). Since we are not adding any gas (nor will we ever add gas to this demo fusor since it is not even close to having the necessary beefy components), we will not have any neutron detection devices, although I will have our Geiger counter next to the unit so students understand the importance of proper detection. We will also operate the demo fusor for only short stretches of time (minutes, at most), and behind a shield to ensure safety from implosion.
The kids are loving this project, and enjoying the learning process! We are hoping to achieve plasma and I would like my posts to serve as documentation of our efforts. We have learned a tremendous amount from this site, so thank you all for the input along the way!
“Whether you think you can, or you think you can't — you're right." Henry Ford
Re: Demo Fusor Progress
Yes, you posted in the correct forum. It looks like a nice little project and am glad that the students are finding it interesting. Just wait until first light. If the vacuum is deep enough you and they will be pleased. All the best on that first run.
One Question: I assume you have two diodes in that PVC TEE. If so, have you grounded the Transformer's metal case and taken its case lead to the fusors base? There are two ways to rectify the Transformer's output. The proper and safe way is full wave. Two diodes one hooked to each transformer knob then the other leads are then joined together. This juncture is the high voltage and goes to the main input terminal and grid on the fusor.
The case of the transformer is a center tap point for the two ends of the high voltage out of the transformer and it must be grounded and this ground will be connected the metal base of the fusor. Without the metal transformer case grounded to both electrical ground at the wall outlet and to the fusor base plate, the transformer case can be a lethal hazard.
I could not see a wire going to the black metal transformer case from ground or the base metal plate of the fusor.
Jim Enright
Richard, thank you for the encouragement and feedback! You are correct that there are 2 diodes in the PVC Tee. The 2 diodes are soldered together with the white bands away from each other. A 16-gauge wire is soldered to each end of the soldered diodes (leading to the sides of the Tee), and a third wire is soldered where the diodes are soldered together (leading to the top of the Tee). The ends of the Tee connect to the HV terminals on the transformer. The top of the Tee connects to the HV feed-through. The wire leading from the top of the demo fusor will be wired to the ground of the transformer. The pictures are misleading in that the two wires coming off of the sides of the Tee are only hooked on to the 2 poles of the OBIT, and the wire leading from the top of the unit is not connected to anything as of right now. We had that vacuum pump and OBIT from a CRT project that we made in the Spring, and I used those items as a way of facilitating the discussion about high voltages and vacuum with the students. Does the set-up I described sound like it will address the issue you raised as far as the transformer case being dangerous?
The kids are very excited as we build the project, I can’t even imagine how excited they will be if we are able to see the light! I know that there will need to be adjustments to the system, but that is just one of the components that I am trying to instill in the students – design, building a prototype, considering changes, problem solving, reflection, etc.
Great! I just wanted to make sure that the metal case of the transformer would be grounded as that is your return path for the high voltage and the winding's center tap.
Jim Enright
Thanks Richard!
Thinking ahead, at some point we would like to convert the housing to a stainless steel chamber, and I'm thinking that a stainless cross would be best. Can we use the same set up but use the stainless cross in lieu of the borosilicate glass and aluminum disks? If that is possible, where would I connect the wire leading from the transformer ground to the demo fusor housing? Would one of the flange bolts be an appropriate location?
In the longer term, I would like to construct a full research grade demo fusor that could eventually be set up to run the deuterium through it. The deuterium lines is much longer term, but I am trying to take steps along the way to advance our learning and knowledge as we progress. This is the reason that we would like to convert the glass and aluminum set-up to a stainless steel housing.
seamus sullivan
Real name: seamus
Post by seamus sullivan »
where did you get the 15kV NST and variac?
just wondering
like the idea of your design
Yes one of the flange bolts would be a great place to place the ground connection. This makes the entire cross body safe to touch. You still have to watch out for your HV input insulator of course. A cross is fairly small and getting a hand too near the insulator is a no-no while in operation even though the cross body is safe then. It is best practice not to be close to any part of a working fusor.
Baby steps taken on the path to real fusion is a wise Idea. I have a full multi-pictorial in the FAQs associated with this forum of my baby steps from 1996-2019. They are numbered 1-5. I consider this series of FAQs a must see for all who would do fusion. Here is the first one.
viewtopic.php?f=24&t=13050
A neon transformer and a oil burner transformer are the ideal for a demo fusor. They are both intrinsically obsolete now and are replaced by electronic HV supplies. These modern items will not work for a demo fusor high voltage source. You must acquire an older used heavy neon transformer or old oil burner ignition transformer. Where to get them?....They are found surplus or at a neon sign shop or at and furnace repair shop. For the short term foreseeable future, these shops are the only source outside of scientific flea markets, or Ham fests. Neon shops are your best first bet as they have a good supply of old used transformers.
Variacs are best found at ham fests. They are just about the only source other than E-bay. I have a paper on ham festing in the rarely looked at "files forum" here on fusor.net.
viewtopic.php?f=19&t=7954
Bob Reite
Real name: Bob Reite
Post by Bob Reite »
You can still buy the "old school" 60 Hz iron core oil burner transformers from a good HVAC supplier, such as SupplyHouse.com It will set you back about fifty dollars. It has to be a big black metal cube with rounded corners. The new inverter based ones are smaller, the cover is plastic and and has more "bulges" on the cover.
One caution about the old oil burner transformers. They do not like being run open circuit for very long. I've had them fail in my oil burner because the electrode gap became too large, so the secondary voltage got high enough to kill the insulation. The fix there was to get new electrodes and adjust the gap, then get a new controller that shuts off the transformer once the flame has "proved". The old controller ran the transformer as long as the oil burner was running, which is not needed for a modern flame retention burner. So do invest in a Variac and run the transformer at no more than 60 volts ac input, until your plasma lights (by adjusting the gas pressure) then once your plasma is drawing current, you can adjust the voltage higher.
Post by ian_krase »
Apropos of being careful with oil burner transformers: I use an oil burner transformer for my system, and today I ran a long (hours) attempt at sputter deposition of aluminum. (I am still trying to ignore logic and common sense and do it without argon).
My deposition was put to an abrupt stop when I realized that the transformer was hot to the touch and the rubber feet I had stuck to it were melted into little puddles! Sadly, with these transformers being potted in insulating resin type material I don't think that adding cooling will be very successful. Quite pleased that it was not destroyed though time may tell.
It is normal for neon sign transformers, that are also potted, to get quite warm due to long on times. The oil burner transformer is no exception. You might read up on neon type magnetically shunted transformers in an old missive I produced years ago. The oil burner transformer is identical to a neon transformer in every respect save for its intended application. I'll place the URL below.
viewtopic.php?f=29&t=10333
