Cube fusor build
Real name: Frank Sanns
Re: Cube fusor build
Post by Frank Sanns »
More great work Jon,
It may just be the physical distance measurement that is giving the effect. If you measured from the outer surface of your Fusor, then you started closer and that would explain the higher numbers that almost met the perpendicular readings as the distance increased. At greater distance, the measurement error on starting distance would be less of contribution.
I am not sure attenuation of neutrons by aluminum is much of a factor. It has a very low cross section so it should not be intercepting many neutrons.
Thanks again for posting the data. Good stuff!
