My progress II
Re: My progress II
Post by Richard Hull » Mon Oct 21, 2019 7:14 am
Mark is correct and you are doing this correctly. With a great demo system that you have you are gaining valuable "operational experience" and I am glad you are doing it with air. In the beginning, back in October of 1997, I spent 1 full year with fusor I and fusor II. I read books on ionized gases, vacuum systems and fusion during this time as well. When it came time to do fusion I was 100% prepared, although there was still a small learning curve as I did fusion in Feb. 1999. I had no real group to look to for help as there was no fusor.net. I was on my own. I first did fusion in Fusor III. I stayed with the lower performing fusor III for 3.5 years as I worked hard on neutron detection systems and went through 3 different detection schemes and used up my first small 25liter bottle of deuterium due to not having a secondary diffusion or turbo pump. I learned after fusor II that any real fusor system is doomed to be a large sprawl of many interconnected pieces of gear and gave up on the idea of a closed box containing a real fusor system.
Keep up the advancing effort which, thus far, is exemplary.
I attach images of all of those 3 early systems spanning 5 years before the advent of Fusor IV. Each image is labeled and explained.
About the best Fusor I could do as the beams would outgas the nalgene 50 microns
of air was as deep at I could pump it. Ran for 3 months
Fusor I - Built in a nalgene dessicator late 1997-Early 1998
First ever "star in a jar" Fusor II below. Ultimately it got dangerous due to beam heating of the glass.
Fusor II - Bell jar system much deeper vacuum 1998 Easy to hit 8 microns of air This demo fusor ran for 10 months. Learned a lot about real operation here.
Real fusion star taken with fusor III below. Running D2 pressure 6 microns never got above 100,000 n/s. Ran from early 1999 until 2003.
Fusor III fusion first done in Feb of 1999 top voltage was 30kv. Got down to barely sub micron using inline foreline trap.
