A Bunch of Successes
Jackson Oswalt
Real name: Jackson Oswalt
Post by Jackson Oswalt » Thu Jan 18, 2018 12:34 pm
Hello all!
I discovered why I had a crappy vacuum. The copper gaskets hadn't made a good seal. I guess it's because of my 12 year old arms not being able to fully tighten the bolts. So, I went to LDS vacuum for some viton gaskets along with 12 point bolts. After replacing the gaskets, I hooked the entire system up to my Edwards e2m5 pump. I pumped it down for 15 minutes and was astonished to see that I had reached 20 microns. Out of curiosity, I gave around 30kv from my 50kv power supply and got the most beautiful, white plasma that filled the entire chamber. Star mode at last! I tried to take a picture, but it was far to bright. At that point, the pressure had rose to 280 microns do to the plasma evaporating contaminates on the grid. I plan to test my diffusion pump and supply some pictures later today.
If you have any questions, concerns, or suggestions they would be much appreciated.
-JO
Re: A Bunch of Successes
Post by Dennis P Brown » Thu Jan 18, 2018 5:22 pm
Very glad to hear. Onward towards a fusor.
Scott Moroch
Real name: Scott Moroch
Post by Scott Moroch » Fri Jan 19, 2018 9:09 pm
Congrats, good work. Just make sure you not looking directly at the plasma at 30 kV as you are probably producing a significant amount of xrays at that voltage.
-Scott Moroch
-Albert Einstein
