Page 2 of 5
Posted: Thu Feb 13, 2020 11:31 am
I tested my hemispheres using a rubber gasket on an old bell jar plate. Check the construction FAQs for my fusor II images. You have so many ports on each hemisphere it would be tough. You would have to blank of all on each hemisphere.
viewtopic.php?f=24&t=13053
Posted: Sun Feb 16, 2020 6:17 pm
by Nicolas Krause
Welding continues steadily, I've nearly completed one hemisphere. The welds need to be cleaned and checked for leaks, and one its quite messy, I might use a dremel to smooth it out. Other than that, simply running out of Argon is what halted progress today.
Posted: Mon Feb 17, 2020 12:44 am
The good news is argon is extremely inexpensive. You must have a small tank. Mine is full sized and I have had it now for 20 years and used very little of it. I fear that when I need a refill, they will note the tank pressure inspection is out of date and charge me an inspection fee in addition to the argon. This is a penalty often impressed upon a small use welder. Big shops never suffer this as they exchange frequently.
Posted: Wed Feb 19, 2020 11:08 pm
by Nicolas Krause
I've nearly completed all the welding on my chamber. A single large weld remains, but having run out of time this evening it will have to wait.
- image1(2).jpeg (124.3 KiB) Viewed 11759 times
Posted: Thu Feb 20, 2020 1:31 am
Good golly miss Molly! Did you get a sunburn doing all of this welding?
If not, you did good....
Posted: Tue Feb 25, 2020 11:10 pm
by Nicolas Krause
Another quick update, I'm happy to report I've completed all the major welds on my chamber. They've been visually inspected and they all appear to be sound.
- image1(3).jpeg (121.38 KiB) Viewed 11509 times
I might in the future have to break out the welding equipment if I have some trouble pumping down, but for the moment all looks well. It's very nice to reached this point, I have a bit of official looking hardware on my desk.
- image2(1).jpeg (119.21 KiB) Viewed 11509 times
I've ordered some 8020 extrusion so that I can build a frame to hold the chamber and assorted components. It should arrive sometime next week. My focus now will move to the vacuum systems of the device!
Posted: Wed Feb 26, 2020 1:45 am
Now your are cookin'! You have to be proud of yourself! I know I am proud that you have proven to be a virtual unstoppable doer. "You have guts and guts is enough" ( R. Lee Ermey, Drill Instructor in the movie Full Metal Jacket)
Looking for continued forward movement and the reports of further successes.
Posted: Thu Feb 27, 2020 12:50 am
by Nicolas Krause
Thanks for the encouragement Richard, it's been a long haul! I can't say enough about the community all the old timers have built here, its such a tremendous source of quality information, the only price for entry is some hard work. I've also been very much enjoying reading your postings about the history of the Farnsworth fusor effort. Fascinating stuff!
Posted: Thu Feb 27, 2020 1:52 am
by John Futter
Nicolas
For a first effort I give you a B+
Well done
Posted: Thu Feb 27, 2020 11:47 am
by Nicolas Krause
I'll take that John! Much better than an F, what would I have to do to take it to an A?
Posted: Thu Feb 27, 2020 3:40 pm
by Mark Rowley
A+ in my book. Here’s why.
You are not a professional welder but your effort and extreme focus are far beyond 99.99999% of most people here who attempt this type of work on their own. ESPECIALLY at your age! Bravo to the extreme!
In the realm of amateur work (which is what this group is about) you get top scores.
Ps...yes, there’s always room for improvement. But that’s true for even the best cut diamond in the history of human existence. Doesn’t mean an A+ isn’t warranted.
Posted: Mon Mar 02, 2020 7:18 pm
by Nicolas Krause
I am now working on the pumping system of the fusor. In addition to the previous vacuum sensor and uC board I've mentioned earlier I also have a surplus vacuum pump and turbopump without controller. I haven't turned on the vacuum pump since I bought it, nor have I monkeyed around with the turbopump. At this point I plan on working on the vacuum sensor circuit, and then building a controller for the turbopump. At that point I can start to troubleshoot the complete vacuum system.
- image1(4).jpeg (105.81 KiB) Viewed 11392 times
Posted: Mon Mar 02, 2020 7:56 pm
by Rich Feldman
Nice looking sock there.
How 'bout starting with vacuum gauge, then characterizing the rotary vane (backing) pump?
Scratch-building a turbo controller would be a learning exercise much bigger than making and welding your chamber parts.
You can go a long way without it.
I would plumb up the chamber, with or without turbo pump, and learn the pumpdown behavior.
Then light a plasma using any old HV power source.
I don't remember whether NST-powered plasmas typically extinguish at pressures attainable with rotary pump (50 micron? 10 micron?)
They sure do in pencil-size glass tubes.
Posted: Mon Mar 02, 2020 8:25 pm
by Nicolas Krause
Funnily enough I feel a lot more comfortable on the electronics side than the machining and welding side. I've got an electronics technologists diploma, I'm 3/4 of the way through an electrical engineering degree, and I've done some embedded programming for a small oil company up here in Canada. I think like a lot of people I initially joined up here hoping to be the one to crack the fusion puzzle, but reality sets in and instead this project has turned into a tremendous self-education tool. While I think building a motor controller would be tough, it's exactly the kind of thing I'd like to learn how to do.
All that being said, I think I'm going to take your advice Rich and test the backing pump with my vacuum gauge first, then I can move on to the turbopump controller.
I do have a couple options for high voltage supplies, I bought a high voltage transformer a few years back and I've got a busted spellmann supply I picked up off of eBay last year. Finally the quickest route might just be to grab one of those precipitator supplies off the internet.
Posted: Mon Mar 02, 2020 9:21 pm
by Mark Rowley
Nicolas, the precip supplies work ok with the 2.75" system but will not put out the current needed for a large spherical arrangement like yours. Theyre cheap enough and it could be worth a try, just dont expect much from them with your arrangement. They may be ok for plasma / vacuum testing as long as you keep a sharp eye on the current draw.
Rich, it's been my experience to have NST driven air plasma extinguish well within the range of a decent roughing pump. Going below 35mTorr things quickly get flickery.
Posted: Tue Mar 03, 2020 12:06 am
by Rex Allers
from Nickolas:
"All that being said, I think I'm going to take your advice Rich and test the backing pump with my vacuum gauge first"
Yes indeed. One step at a time when possible and that is a basic good one. What kind of gauge have you?
If your gauge is good and on the pump input that sets the best you can expect at the pump.
I'd use just that one pump first onto your chamber to see if you can prove there are no big leak problems. If things look good seal the chamber off and see how it holds the max vac you achieved. That should define any minor leak issues.
Last, go on to add the secondary pump (Turbo or diff). At lower levels outgassing issues might look like leaks.
Issues along the way need to be worked on or thought through. You are doing great.
Posted: Tue Mar 03, 2020 1:07 am
by Nicolas Krause
Hi Rex,
I have two, a pirani and a thermocouple. I'm going to start with the thermocouple, build a circuit and write a little program to measure the pressure and update a spare LCD I've got lying around. As far as my vacuum pump. there are a couple issues, first it has no electrical chord atm, and second its leaking a decent amount of oil from the black tube out its back. The pump is a leybold trivac D4A, I've managed to find a copy of the manual online, so I'll go through that next.
Posted: Tue Mar 03, 2020 2:08 am
by Rex Allers
Re:
" its leaking a decent amount of oil from the black tube out its back"
That sounds unusual to me. Not sure what to make of the black tube or this leak of oil. Not something I would expect from a normal working pump.
Key, I guess, is what vacuum you get at the input of the mechanical pump. Second, does it have other issues -- like: what's with this oil you mentioned.
Posted: Tue Mar 03, 2020 9:15 am
Is this leak in between the motor and the back of the pump body? If so, you have a shaft oil seal leak.
A year ago I purchased an Edwards speedivac 2 at a yard sale for $5.00. It leaked oil, copiously, at the seal. I finally got around to ordering the oil seal ($32.00 - Duniway). Installed it and cleaned the fairly clean looking guts. It had a decent vacuum to the thumb over the inlet once new oil was in it. After the fix, I had zero oil leak. Unfortunately, it would not indicate on a TC gauge. So, I hooked up to the normally shunned, but telling 0-30-inch gauge and it would pull 26-inches!!! (~40 torr!!). I was hoping for at least 20 microns, (0.02 torr). I now have a perfectly sealed, worthless pump. Oh well....
Posted: Thu Mar 05, 2020 9:27 pm
by Nicolas Krause
After reading parts of the manual and inspecting the pump visually the leak appears to be from one of the oil drain ports. So it may not be a leak after all! A black rubber tube is hooked up to a brass fitting and it is this tube that the oil is draining out of. I'm not sure if anyone can explain the reason for this hookup, in the manual it shows a screw in the drain port. I had to put a new power chord in place, the old one had been chopped off. I'll wait to put the cover for the power chord connection back on until I've ordered a strain relief plug, the current one I have is too small for the chord in question. After making the connections I've plugged it in and the pump turns on and appears to work without too much trouble! I'll have to complete my vacuum gauge circuit next to characterize the pump.
- image2(2).jpeg (84.33 KiB) Viewed 11142 times
- image1(5).jpeg (114.16 KiB) Viewed 11142 times
Posted: Thu Mar 05, 2020 11:42 pm
It is obvious that the pump was in a place or position where the pump would not allow for easy draining to replace oil. The tube will go to a drain pan at a lower, convenient location. The hose would have a petcock that could be opened to drain the fouled or old oil.
Posted: Fri Mar 06, 2020 12:47 pm
by Nicolas Krause
Thanks for the explanation Richard, I do have another question. I'm missing a small number of vacuum parts for the hookup to my chamber, a couple clamps etc. that I plan on ordering soon. Once those parts arrive, if I put my turbopump in series with my backing pump, and leave the turbopump off, can I just turn on the backing pump without causing any problems? Having read a number of other threads I know that if I turn on the turbopump without the backing pump operating I can do some serious damage, but if the turbopump is off will it just act as a bit of additional tubing?
Posted: Fri Mar 06, 2020 2:59 pm
Absolutely! Same goes for a diff pump. It is just another "hanger-on" in any vacuum system if it is not turned on. The proper way to work a system is to open all valves and pump the entire vacuum system down as low as the mechanical pump can go. (hopefully at or below 50 microns) Once at fore-line vacuum, the secondary pump (turbo or diff pump), is turned on and you are off to the races from there.
All of the above assumes that your system is sealed and tested. During testing, a stepped assembly process is demanded to be sure you are sealed at each step. This can be a tedious process. Newbies tend to assemble the entire system and then wonder why they can't get a good vacuum as they now have to hunt for issues and leaks.
System assembly absolutely demands a TC gauge at minimum!!! In the last stage a deeper reading gauge on the reactor vessel would be nice, leaving the TC gauge in the fore-line permanently. This means you need a lot of blank offs, clamps and adapters if seeking to do a professional level job of it.
Note: Valves in a vacuum system are more for isolation, shut-down and compartmentalized tear down or modification of the system without fouling the entire business if one component needs replacement or a new one added in the middle of the system. There is no such thing as too many valves.....(if you can afford good ones.)
Posted: Sat Mar 07, 2020 1:47 pm
by Nicolas Krause
Earlier this week, my 8020 frame arrived. I had to wait a few days for my M8 Tap to arrive, but on Friday it did and I've completed tapping the ends of the extrusion so it can all be put together. I plan on mounting the vacuum chamber in the center of the frame.
- image1(6).jpeg (110.36 KiB) Viewed 11476 times
Posted: Sat Mar 07, 2020 5:03 pm
by John Futter
Nicolas
I would srongly suggest you do a pressure test on your chamber first.
Ie blank off everthing and feed shop air at 15psi (no more)into your chamber through your gas feed line
Use 50:50 detergent and water and go round every weld and vacuum joint with a small paint brush dipped in the detergent water mix and look for foaming or bubble formation
this method far quicker than trying to use vacuum in the first instance
only when you pass this stage put the chamber under vacuum
