Vacuum Chamber Construction
Nicolas Krause
Real name: Nicolas Krause
Post by Nicolas Krause »
This is an end of summer update. My purchase from LDS vacuum arrived at the end of July, and I now have the necessary hardware to complete the vacuum chamber. While I had intended to complete the welding by the end of August, getting setup for TIG welding has taken longer than anticipated (as always seems to be the case). The local makerspace does not have a TIG welder, and I've had to turn to other means. I've purchased a small TIG machine on Amazon from HitBox, and while it turns on, sourcing all the other components, such as TIG electrodes, a small bottle of Argon gas, a regulator, 220V dryer plug adapter, has been an education in and of itself. Its taken me the whole month of August to obtain all the bits, sharpen the electrodes, find a bottle supplier, get the bottle filled etc... I'm returning to school this Tuesday and will have to pack away the hardware for the summer. This means I'll likely return to work on my simulation when time allows, and hopefully at Christmas I'll be able to find some time to work on welding of the chamber. I'll be on a co-op term from January to April so ideally I'll be able to complete the chamber after work hours during the winter.
ian_krase
Real name: Ian Krase
Post by ian_krase »
Where are you doing your welding? Do you own a house with a garage, or do it somewhere else, or what?
Nicolas Krause
I don't own a house unfortunately, I had planned on appropriating the dryer plugin in my parent's laundry room and running an extension cable outside through a window so I didn't have to worry about the fumes/gas. The welding machine I've bought is quite small and portable so it shouldn't cause too much of an issue. If I'm welding in the winter I'll look at heading to the local makerspace with my setup as I believe they're wired for 220v and have a large ventilated bay.
Nicolas Krause
Just a short update, I've managed to get the mecrisp-stellaris version of forth loaded onto my board and am now monkeying around with the language in my spare time!
Nicolas Krause
After completing another semester of school in Victoria, I'm now on an 8 month co-op in Edmonton. I've joined the local makerspace and setup my TIG welder for the first time tonight. I'm currently practicing on some scraps of steel I've got lying around, and boy do I need it! I'll probably keep practicing until I feel comfortable and then go ahead and start welding the components of my vacuum chamber. At the moment I've got a lot to learn, and I'm just trying to get better at controlling the puddle.
Keep practicing, you will get there. Getting the current set right and your speed during the weld is critical. The puddling, if done well, will sort of set the speed of movement automatically as you get familiar with it.
Nic
You need some scraps of stainless about the same thickness as you are going to weld in anger
stainless is very much different from steel to weld --infact I find stainless much easier --but I was taught how to weld on Stainless
good Luck
Nicolas Krause
Thanks for the tip John, I found a metal supermarket up here in Edmonton and picked up some 304 SS offcuts of about the same thickness as my chamber. Last night I was able to get setup and make some passes, the photo below shows some of my handiwork. I started on the right just passing the electrode and controlling the puddle, then I added in the filler rod. Wasn't great to start but the welds started to improve. At that point I'd mucked up my electrode and had to regrind which accounts for the mess after a few decent lines. When I went to restart the welding mask I was using started to go on the fritz, it wasn't auto-darkening properly. I'd read some decent reviews online that I thought justified me saving a bit of money on some safety gear from China. Rather than try and fix it I think I'm just going to write off the cost since I bought the cheapest I could find and spend a bit of money on a half decent one.
Post by Rich Feldman »
I can attest that sunburn is a risk if you skip the gloves and long-sleeve shirt, buttoned up at least as far as the bottom of welder's mask.
Even TIG welding can occasionally pop & launch a shower of sparks,
actually incandescent droplets of steel which you don't want to fall into your shoe or pocket.
Nicolas Krause
I've continued to practice my welding, and its slowly improving. A lot of the work still looks pretty ugly, but I did my first joint last night and I can reliably put down an ok line on a flat piece of steel. I've got to monkey with a bunch of settings around my TIG torch, but the fabrication series on youtube has been a big help and has answered a lot of questions I've had. I've got to grab a bit more Argon gas as I've only got a small tank, but mostly I think I just need some more time in the saddle.
Nicolas Krause
Just a quick update with regards to the welding. As per the photo below, I've had a marked increase in the quality of my welds. A number of things have helped, I'll note the following. First I've changed the nozzle on my tip. I am now using a size 12 with a gas diffuser, and the shielding from the Argon is much improved. It was quite cheap, I think 30$ for a whole set of attachments off of Amazon. Secondly, cleaning and weld preparation makes a huge difference, I'd been lazy about setup to start, but cleaning the piece with acetone, making sure everything is stable and well aligned really does make the welding easier. Thirdly, I was putting too much filler rod into my welds, it's more a case of pushing the puddle forward with the arc, adding some filler, removing the filler rod and then pushing the puddle forward again. Finally, more power is better, I had been nervous about the amperage setting to begin with, but putting it on low makes it harder to weld. You've got to have enough power to move steadily and quickly, if not you mostly heat the metal rather then weld it. I do have a question about the colour of the welds, I understand that for steel the weld should be basically shiny and steel coloured, I've got a bit of a rainbow going on and I'm wondering if its something I can get away with, and if not, how do I reduce the coloration?
Some coloration is unavoidable. forget it. I do hope you are aggressively wire brushing the weld once cooled. You will be amazed at what a heavy steel brushing will do for the appearance of the weld. Do it by hand or with a round brush in a power hand drill.
Good weld!.....Needs a heavy steel brushing to beautify it
"Learning by Doing".....It's The Only way!
Nicolas Krause
Another practice weld was successfully completed tonight, and after seeing the colour of the weld after brushing I decided I was ok to move on to the actual welding of the chamber.
The fit between the two pieces was tight enough that I didn't need to use any filler rod. It's not perfect, but I'm quite happy with how it turned out. I do need to find a small wire brush though as I wasn't able to fit the current one in the chamber to properly clean the weld.
Smaller round wire brushes on a shaft will fit on a power drill and wire brush inside welds very well. Very tiny tightly confined welds can be brushed using a Dremel tool and its very small wire brush attachments.
Your interior weld is excellent looking. I deliberately machine all my fittings so that no form of wire feed is needed. Just simple fusion and a tiny bit of sacrificial lip or ledge supplies the filler metal by fusion to the joint. I hate wire filler feed and avoid it at all cost unless there is no work around.
Nicolas Krause
I've ordered some small wire brushes for a few dollars, hopefully they'll fit, if not I'll look into finding a dremel. I do have a question about testing the soundness of the welds. I understand there are special dyes you can purchase to see if there are any cracks/leaks in the weld. Given the need for the welds to be airtight I was wondering if they were useful for checking for leaks or if it was better to troubleshoot once the whole system is hooked up to pumps.
I tested my hemispheres using a rubber gasket on an old bell jar plate. Check the construction FAQs for my fusor II images. You have so many ports on each hemisphere it would be tough. You would have to blank of all on each hemisphere.
viewtopic.php?f=24&t=13053
Nicolas Krause
Welding continues steadily, I've nearly completed one hemisphere. The welds need to be cleaned and checked for leaks, and one its quite messy, I might use a dremel to smooth it out. Other than that, simply running out of Argon is what halted progress today.
The good news is argon is extremely inexpensive. You must have a small tank. Mine is full sized and I have had it now for 20 years and used very little of it. I fear that when I need a refill, they will note the tank pressure inspection is out of date and charge me an inspection fee in addition to the argon. This is a penalty often impressed upon a small use welder. Big shops never suffer this as they exchange frequently.
Nicolas Krause
I've nearly completed all the welding on my chamber. A single large weld remains, but having run out of time this evening it will have to wait.
Good golly miss Molly! Did you get a sunburn doing all of this welding?
If not, you did good....
Nicolas Krause
Another quick update, I'm happy to report I've completed all the major welds on my chamber. They've been visually inspected and they all appear to be sound.
I might in the future have to break out the welding equipment if I have some trouble pumping down, but for the moment all looks well. It's very nice to reached this point, I have a bit of official looking hardware on my desk.
I've ordered some 8020 extrusion so that I can build a frame to hold the chamber and assorted components. It should arrive sometime next week. My focus now will move to the vacuum systems of the device!
Now your are cookin'! You have to be proud of yourself! I know I am proud that you have proven to be a virtual unstoppable doer. "You have guts and guts is enough" ( R. Lee Ermey, Drill Instructor in the movie Full Metal Jacket)
Looking for continued forward movement and the reports of further successes.
Nicolas Krause
Thanks for the encouragement Richard, it's been a long haul! I can't say enough about the community all the old timers have built here, its such a tremendous source of quality information, the only price for entry is some hard work. I've also been very much enjoying reading your postings about the history of the Farnsworth fusor effort. Fascinating stuff!
Nicolas
For a first effort I give you a B+
Well done
Nicolas Krause
I'll take that John! Much better than an F, what would I have to do to take it to an A?
