My fusor's blueprint is similar to a lot of first fusors:
Vacuum chamber: 2 6" SS hemispheres
I will drill holes in various locations to fulfill the needs below:
Vacuum, leybold d16a-max 3x10e-3 Torr, with a vacuum gauge near chamber duct
Voltage, variable transformer connects to rectifier that transmits AC into DC, wires connect to conductive source that sends voltage into the inner grid, detectors use voltage duct for readings
Viewing, temperature resistant glass, so you don't get your face burned and so vacuum isn't compromised
Pressure gauge
Maintenance for fixing grids and leaks
Deuterium needle valve inlet port with gas regulator, 1 sccm at beginning
Tungsten wired inner grid
Cooper wired outer grid
Volume of my chamber (EDIT): 799.88 in³
Basic, yet somewhat informative let out of my design
Ever Fusor has flaws
X Ray and neutron detectors would be operational near main power source
My vacuum pump reaches max vacuum at 3x10e-³
Basic Fusor Mk 1- 6" diameter
- Real name: Dan Faust
Live long and prosper-Vulcans (Star trek)
Not knowing our end should never discourage us from achieving more
