Commonwealth Fusion's High Temp Superconducting Magnet Success
Re: Commonwealth Fusion's High Temp Superconducting Magnet Success
Post by Rich Feldman »
Thanks, Andrew.
Can you save us the trouble of hunting for a doc that's not a glitzy promo video,
to learn things like dimensions and turns-count, and about using HTS superconductors at 20K?
So techies can better grasp the details which are novel.
The 3D rendering is kind of ambiguous about whether the B arrow is inside the bore of future toroid,
or at edge of winding where field is much stronger and the superconductive material cares.
Here are some guesses from basic principles & Internet searches about HTS, later compared with numbers from CF sites.
I figured the current to get B = 20 T at the surface of a round conductor bundle.
H = B / u0 = 15.9 million A/m. That should be the same as 200,000 oersteds.
If the bundle diameter is 20 cm (7.9") then it must conduct exactly 10 million ampere-turns.
Video by CF says 40 kA, so there would be 250 turns. Packed area 1.26 cm^2/turn.
Average current density 31.8 kA/cm^2.
Internet searches for HTS Magnet pop up values of that order. The critical current depends strongly on material and temperature and magnetic field strength. What fluid is used for freezing bath at 20 K?
High pressure helium gas! https://www.psfc.mit.edu/sparc/hts-magnet
As coil diameter goes down, required current density goes up.
For D = 12 cm (4.7") the circumference is smaller, so we need only 6 million ampere-turns.
150 turns at 40 kA. But now the area per turn is only 0.75 cm^2, and average J is up to 53 kA/cm^2.
Can that be handled by real coilable materials at the stated T and B?
Found more at
https://www.cambridge.org/core/journals ... 1764EF9FF0
The real SPARC will have a bore with B0 = 12.2 T and R0 = 1.85 m. So the toroidal magnet current must be 112,850,000 ampere turns. 18 units with 6.27 MA each.
Am reminded of advances in electric motor compactness during 20th century, driven as much by increased magnet wire temperature as by improvements in electrical steel.
In today's case, improved magnet grade HTS. CF estimates that their demo coil has 10% of the world inventory.
Andrew Seltzman
Real name: Andrew Seltzman
Post by Andrew Seltzman »
Unfortunately I don't know as I work in the PSFC, not CFS. I believe a few papers will be forthcoming.
Andrew Seltzman
www.rtftechnologies.org
Thanks again. Duck Duck Go helped my hunt, and Excel saved wear on the slide rule.
Here's a chart from the CF paper cited near bottom of my post full of numbers.
urn cambridge.org id binary 20200925120924322-0810 S0022377820001257 S0022377820001257_fig1.png
Skeptics will look at the Q curves and say "yeah, right".
Be interesting to look at charts of inertial confinement projects, from when NIF was at this stage of planning.
[edit] And the papers Andrew mentions will tell us all about the engineering numbers. And conductor fabrication, insulation, physical support, etc. Quick, what's the magnetic force on wire carrying 1 million amperes in a B field with transverse component of 1 tesla?
Agree with RIchard Hester about the promise of HTS in other big magnet applications. What will Florida National Magnet Lab do? They are a leader in high field solenoids: at least 33 T with water-cooled multi-megawatt Bitter coils, and I think over 40 when resistive coil is surrounded by a traditional superconducting coil.
Apparently the HTS and surrounding regular conductor are produced in tape form, then wound in a spiral like recording tape to make one D-shaped layer. The demo magnet is a stack of 16 layers, each of which is said to be the biggest HTS magnet in the world today.
The SPARC intro paper gave me a chance to draw and learn. Here, overlaid on their drawing, is green circle representing torus with the given R0 and a dimensions. Smaller circles were overlaid to "measure" the winding inner and outer radii. Above that I drew a polar view with 18 torioidal-field coils.
As mentioned in prev post, we know the current from basic principles. For 12.2 T field at R0, the total current is 112.85 million amps. 6.27 million amps per coil. Field will be 17.6 T at inside edge of torus and 9.3 T at outside edge.
What if 17 coils were powered down and one were operated by itself, as with the slightly smaller demo coil? Using formula for a circular current loop, we'd get 2.96 T at center of loop (my blue dashed line), 3.16 T at R0, and about 20 T when 7 cm away from the current filament.
https://tiggerntatie.github.io/emagnet/ ... ulator.htm
Finn Hammer
Real name: Finn Hammer
Post by Finn Hammer »
All,
Please bear with me on a small detour from Rich's excellent calculations of magnets.
One of the things that has disturbed me in the past is the claims of elevated temperatures to the tune of millions of degrees, inside the fusion devices competing for public interest and the associated funding.
On the path to understanding these claims, I came to the conclusion, that these temperatures are a measure of the speed of the particles involved.
But also that these speeds could only be acheived in a low pressure environment, so that the temperatures quoted lost their meaning to the layman audience relating it to an atmospheric context.
In short, if the particles had this speed out here in atmosphere, the result would be these increadible high temperatures, but it is happening in a near vacuum, so....
Within such a context, the claims of elevated temperatures seemed to be manipulative in nature, if not in fact bordering on the fraudulent.
However, from this source:
https://www.machinedesign.com/news/arti ... ear-fusion
I read this:
""During its 23 years of operation, the Alcator C-Mod reactor has repeatedly set the record for plasma pressure, increasing its fusion rate with each improvement. This time, it beat its 1.77-atmospheres record set in 2005 by 15%, reaching 2.05 atmospheres and temperatures twice as hot as the sun. ""
If it is correct, that the plasma is pinched and thereby compressed to 2.05 atmospheres, then the temperatures quoted, inside the plasma, is not just a speed number inside a void, but actually a measure of a "real" temperature, as it would have developed out here in the real world.
This definitely has changed my respect and awe of the status of the present research.
Cheers, Finn Hammer
Richard Hester
Post by Richard Hester »
I did my thesis work right next to what used to be the highest field magnet in the world - it was a pair of nested solenoids, one a conventional Bitter magnet, and the other a superconducting solenoid. If I remember correctly, state of the art at the time ('74-'75) was 14T. I could also throw a rock (not very hard) and hit the current incarnation of MIT's Alcator tokamak, which at the time boasted conventional copper electromagnets cooled with LN2.
I was working with a group that was generating pulses of terahertz radiation using a CO2 laser and methyl fluoride gas. We used the magnet in one of our experiments, and I had the job of machining a tube to fit down inside the magnet bore.
Finn... Back in 2014 I did a FAQ in the fusor theory forum that dealt very completely with fusion temperatures that are little white lies told by scientists to reporters to impress the down at heel dullards in the public. Makes for good press and funding to talk in millions and billions of degrees. I wrote the FAQ when I failed to realize a lot of folks arriving here had no idea about temperature beyond "Ouch! burny-burn, That's hot Ouch!!...or...."Oh man, is it cold! It's freezing!" here is that FAQ.....
viewtopic.php?f=42&t=10424
Those high-field solenoids find use in testing practical superconductive wires and tapes
for critical current at various values of T, B, and B orientation.
Found this chart at the Florida lab's site, under:
Engineering Critical Current Density vs. Applied Field for Superconductors Available in Long Lengths
Note that in some curves the data stops at 20 T.
And that all are measured at 4.2 K.
Critical current densities are much lower at 20 K, and lower still (mostly nonexistent) at 77 K even at B=0.
As CFS has demonstrated, it looks like HTS technology greatly extends the B range of superconducting magnets,
esp when cooled far below critical temperature.
What are the economies of refrigeration to 20 K instead of 4.2 K? 4.2 K instead of 1.9 K?
Anyway, we can now talk about 100 million amps DC with a straight face. Bet the number is even bigger for ITER.
[edit] Back to resistive Bitter solenoids, I remember a power density number from some Florida design about 10 years ago.
13 watts per mm^3, that's 13 kW per cm^3. Would make a great tankless water heater. Advances have been in cooling and mechanical strength.
Justin Fozzard
Real name: Justin Fozzard
Post by Justin Fozzard »
A huge elephant in the room for devices such as CFS's are the material limitations of the plasma-facing first wall.
With current technology the first wall loading limits are 2MW per sq.m for neutrons and 20MW per sq.m for heat, meaning that to be economically viable, a device will require a large first wall area, and thus large volume in order to produce a reasonable amount of power.
For example, a toroidal configuration with a 1.5m major radius and 0.5m minor radius has a surface area of around 30 sq.m, so the neutron loading limit would be only 60MW; not enough power production to be of commercial interest, especially compared to the relative simplicity of gas turbine or diesel powered generator sets or even a couple of wind turbines.
Another rarely mentioned issue is the lithium/beryllium blanket that will have to surround the first wall to slow down and capture the neutrons to avoid damaging the superconducting magnets.
The forces between large superconducting magnets at 20T will be rather interesting as well....
Any strengthening or increased output solution at one end of a power system that is positive or efficacious will typically force other engineering challenges to ripple throughout the system. Excellent solutions at one end that have plagued development to any point will usually require seemingly insuperable problems across the board that often, even if solved, make the system too expensive or unable to warrant such costs on a planned mission goal
Justin mentioned:
Yup. Each D shaped coil really wants to expand and form a circle,
and really wants to get cozy with neighboring D's.
Fortunately the attraction of left and right neighbors almost cancel each other, as long as all coils carry the same current.
Not counting tidal forces, which compete with the magnetic compressive (pinch) force within each coil bundle.
Suppose we energize just two neighboring SPARC coils with nominal 6.27 MA each.
The straight vertical sections near the tokamak axis are 0.314159 meters apart (1/18 of circumference of 1.8 m circle).
Each generates 4.0 T radial field at the neighboring vertical coil section.
The attraction per lineal meter is 25 MN (5.6 million lbf), 83% of Space Shuttle nominal total thrust.
Return to “Fusion --- Past, Present, and Future”
