Any strengthening or increased output solution at one end of a power system that is positive or efficacious will typically force other engineering challenges to ripple throughout the system. Excellent solutions at one end that have plagued development to any point will usually require seemingly insuperable problems across the board that often, even if solved, make the system too expensive or unable to warrant such costs on a planned mission goal
Commonwealth Fusion's High Temp Superconducting Magnet Success
Re: Commonwealth Fusion's High Temp Superconducting Magnet Success
- Rich Feldman
- Real name: Rich Feldman
Justin mentioned:
>>The forces between large superconducting magnets at 20T will be rather interesting as well....
Yup. Each D shaped coil really wants to expand and form a circle,
and really wants to get cozy with neighboring D's.
Fortunately the attraction of left and right neighbors almost cancel each other, as long as all coils carry the same current.
Not counting tidal forces, which compete with the magnetic compressive (pinch) force within each coil bundle.
Suppose we energize just two neighboring SPARC coils with nominal 6.27 MA each.
The straight vertical sections near the tokamak axis are 0.314159 meters apart (1/18 of circumference of 1.8 m circle).
Each generates 4.0 T radial field at the neighboring vertical coil section.
The attraction per lineal meter is 25 MN (5.6 million lbf), 83% of Space Shuttle nominal total thrust.
