Progress in Fusor Plasma Simulations
Liam David
Real name: Liam David
Post by Liam David »
Progress update since I've been quiet lately.
I held off on machining a cube-like fusor in the hopes that simulations will give insights on electron/ion behavior and general plasma dynamics. Much of my effort these past several months has been spent on writing a fully collisional, GPU-accelerated, particle-in-cell plasma simulation from scratch. I'm happy to say that after much debugging, the code is almost complete. I'll go much more in depth in the future when everything's done, but here's a very basic outline of how the code works:
  • Import CAD model, generate initial electric field, prepare cross-section data
  • Initialize all arrays for particle position, velocity, etc... included species: D+, D2+, D3+, D2, D, e
  • Move relevant data to the GPU
  • In a loop:
    • Find collisions of particles with background gas using previous timestep's particle velocities
    • Delete particles that reacted, add products
    • Move particles using Boris algorithm (will be adding magnetic fields soon)
    • Delete particles that impact the cathode and chamber
    • Add secondary electrons from ions that impact the cathode
    • Find particle densities, charge densities on the simulation grid
    • Compute space charge and new electric field
    • Compute the fusion rate using energy-binned particle densities
    • Repeat indefinitely, or until some criterion is met
Porting parts of this code to the GPU has resulted in a massive speedup over a standard CPU implementation - of the order 100-1000x, depending on the operation. It's very necessary since the electron timestep is 2e-12s and I simulate several microseconds...
The results are in good agreement with other simulations and measurements. Central ion densities are on the order of 1e15/m^3 and computed fusion rates are ~1e6/s - 1e7/s. As expected, the vast majority of fusion reactions are beam-background and fast neutral-background, with the total contribution of beam-beam being a negligible ~0.0001% of the total. Further crushing hopes of recirculation in standard fusors, in the 10 - 50mtorr range the mean free path of D+, D2+, and D3+ ions is abysmal at a few cm.
Fields in my current fusor.
Included atomic/molecular processes.
(Unsmoothed) cross-sections for all included processes.
At 10mtorr deuterium. Discontinuities due to limits of cross-section data.
D2+ ion density near center of fusor.
Simulation of discharge between parallel plates, showing reasonable agreement with Paschen curve - albeit slightly shifted. I've been using this an indicator of the physical accuracy of my code. The most recent revision is even better.
Nicolas Krause
Real name: Nicolas Krause
Re: Progress in Fusor Plasma Simulations
Post by Nicolas Krause »
Wow! Fantastic work Liam! Is the simulation 2d or 3d? For the first diagram of the fields in the fusor, what package did you use to plot the vector lines, it looks great!
Liam David
It's 2D but represents 3D cylindrical geometry, revolved 180 around the horizontal midline. The electric field is plotted using the Matlab streamline function, nothing fancy. Everything is written in Matlab (including visualizations) and CUDA C.
Curious did the calcs take into the consideration the central grid geometry? I wonder if the math would go very complex with a 6-inch spherical chamber with a 1.5 inch wire geodesic with 12 or 16 openings? (12 to 16 streamlines like my avatar of fusor III's early imaging.
Nicolas Krause
Richard, I believe if you look at the diagrams Liam has posted, he's modelling a cylindrical grid of the type that's been used in a number of the cube fusors. As far as your question with regards to different grid geometries, the best reference I'm aware of is Matthew Lilley's work on ion orbits in the fusor. He investigated a 2d simulation of the standard fusor type grid you're asking about. I don't know that the math is any more complicated than what Liam is doing (which is quite complicated), but a relationship between the stable orbit of a particle and its initial distance from the grid was demonstrated in the work I linked too.
Nicolas Krause
How many particles can the simulation run effectively Liam? 10's of thousands? 100's? Millions?
Nathan Marshall
Real name: Nathan Marshall
Post by Nathan Marshall »
Fantastic work, Liam! I am impressed. Great job getting things ported to GPU. This is definitely one of those "pleasingly parallel" problems where GPU is the obvious choice. How long does a microsecond-scale simulation like this take, and what GPU are you running this on?
Liam David
Nicholas is correct, I'm modeling a cylindrical geometry. I'm not doing any math that's explicitly geometry-dependent--the simulation tracks individual particles that accelerate via the electric field, which is calculated numerically on a mesh from boundary conditions. Changing the geometry is as simple as changing the boundary conditions, which can be done manually or with a CAD model. While it's been a long time since I ran a simulation with a more traditional fusor configuration, back then I got star mode to form quite easily. My compute time is currently saturated with hundreds of Paschen curve validation simulations, but perhaps when that's done I'll redo those older sims...
Each particle represents 250,000 real particles at the moment. I can simulate as many particles as the GPU VRAM will hold, and I'm also limited by the GPU kernel timeout of 2s imposed by the OS. It'll run tens of thousands very quickly and millions with no issue. Each timestep takes ~1-10ms depending several factors. If I turn off atomic/molecular processes, space charge, and all the more involved computations, I can get <<0.1ms per step due to the massive parallelization. A microsecond-long simulation takes on the order of 10-20 minutes. Currently I'm running this on a laptop with i7-6700hq and a GTX 960m, but I'm about to upgrade to a R9-5950x and RTX 3080 desktop which should allow me to run many simulations in parallel and in much less time.
I've looked at some of Matt Lilley's work including that poster, but I haven't found his code anywhere. I'm not convinced that analytic approaches are sufficient due to the immense complexity of the dynamics. Space charge, collisions, etc.. are very much nonnegligible, and given the abysmal mean free path of D2+ and D+ at standard fusor pressures, I don't think the mechanism he suggests is the full story. But it's interesting work and I think I understand his analysis of the ODE.
Joe Gayo
Real name: Joe Gayo
Post by Joe Gayo »
Nice work Liam.
Do you have a plot of the plasma potential vs. linear distance through the cylindrical axis of the cathode?
Liam David
Here's a plot of the potential along the centerline. Conditions are -50kV, 50mtorr, and 1.1us. The particle densities and potentials are still rising at this point, and I'm hitting my hardware limitations for this laptop. Please ignore the disparate plot formatting...
1D plasma potential
1D plasma potential
2D plasma potential
2D plasma potential
D2+ density
D2+ density
I've avoided reporting it thus far, but two effects that several people have observed in their fusors are present in this last image, namely the off-axis beams and shiny ring bisecting the inside of the cathode.
Mine: viewtopic.php?f=18&t=13542&start=30
Jim: viewtopic.php?f=18&t=13077&start=70
Jon: viewtopic.php?f=6&t=12954&start=20#p85463
The high pressure allows for a self-sustaining discharge off-axis, and the field simply focuses the ion beam to a point. In my fusor, I see this fade and disappear as the pressure drops and voltage rises. The ring is simply the plane of zero axial electric field, so any slower ions that cannot "miss" the cathode will converge towards this point. The electric field plot in the first image of this thread makes this pretty apparent.
I think I also have a basis for the color bands seen on the ends of the cathodes, but I'll hold off until I'm more sure of the results.
The challenge I'm currently facing is getting the chamber to breakdown at the voltages and pressures I measure. While I get very close to the theoretical parallel plate Paschen curve, the fusor is proving trickier. Experimentally I can easily get plasma at ~10mtorr (gauge corrected for deuterium) and some 50kV, but I require ~50mtorr in the simulation. I think there's some process I'm leaving out... probably not thermionic emission, especially for a "cold start", but perhaps cold cathode emission? I ran the numbers using the equations found in the Wikipedia article, but get a negligible current density.... I do include secondary electron emission in the simulation.
Nicolas Krause
I'd contacted Matthew Lilley a few years back asking if I could see his code. He let me know he doesn't have it anymore, I believe it was written in Fortran and he indicated it was a poster for a conference, I don't know if he was trying to get funding for a project or look better on the job market but it's over a decade old at this point. I agree that the dynamics are very complex, I guess the reason I'm interested in the non-linear methods he was attempting is two fold. Firstly, it seems a good way to try and overcome some of the limitations amateurs like us have, buying a supercomputer to simulate some ungodly number of particles is a bit out of reach. Secondly, I think trying something different allows you to make different discoveries, I understand that PiC simulations are the standard for plasma modelling, and with very good reason, but I like the non-linear math and instead of trying to copy what everyone else is doing at least its a different tack.
Liam David
I'm not trying to downplay a more analytic approach - quite the opposite. I think it complements simulations and can give some great insights, as Lilley's work demonstrates. It'd be interesting to see if I/we could replicate some of his results, and how well that lines up with his ODE... we could solve it numerically after all. To word what I meant earlier more carefully, it's important to recognize idealizations where they exist, and much work on fusors over the years has shown that they don't work quite like we thought, as in recirculation, beam-beam reactions, and all that. I'm quite the math-y guy and really do enjoy PDEs and the like....
Agreed, any path to discovery and learning more about what we are doing to increase the yield is for the best, regardless of how it is arrived at, be it via simulation or in hardware. I have long believed there is no one explanation for how all fusion is done in the simple fusor.
Nicolas Krause
Ah right, I see what you're saying Liam, yes I'd definitely agree with that. The whole art of simulating is picking the right simplifications so that the model captures the desired behaviour. I think the reason I'm interested in Lilley's work, is Richard talks a lot about how he has to condition his fusor to get good fusion numbers. The leading theory being that this is created by wall loading of the device with deuterium, this seems to be the furthest starting point for an orbit one could imagine. So the mechanism in my head is like so, a stable orbit leads to more chances to fuse, so an increase in the number of particles with stable orbits increases fusion, the best way to increase stable orbits is by starting the particles from their furthest possible point. The best way to do this is with wall loading. That's sort of the logical chain of thought I have regarding Lilley's work, no clue if people here would agree or disagree with it, but it seems to me plausible.
I have always believed the walls on the long MFP in 6" and larger fusors was charged with neutral D molecules/atoms over time. Bombarding electrons at near full energy and even some neutrals of high energy pop imbedded D out at some X value of sufficient loading as Deuterons to undergo full acceleration towards the grid. Due to MFP few make it, fewer still circulate. Fusion occurs in velocity space within the spherical fusion reactor. This was pointed out by empirical experiment way back in 2004 by U of W. In 1999 Robert Hirsch told me he believed our fusion took placed in velocity space and not in a thermal environment. Velocity space includes inside the grid, but the grid represents near zero volume in the sphere related to the overall volume of the vessel.
Spheres offer only increased 360 degree volume of velocity space over a well done BOT type design. There are many other rare processes fast neutral/wall D fusions, neutral/neutral, neutral/deuteron, the list goes on and on. This is not to boost the sphere as a fusor, for I have already denigrated it for its well proven lower neutron and fusion production over other designs already extant and in use here. I work it more for aesthetics than any other reason now.
Liam David
Just a quick update as I work on a new and improved (read: much faster and with fewer bugs) iteration of the code. Some eye candy with ion optics:
https://youtu.be/XyJW5LpbuBE
Nicolas Krause
Lovely visualization Liam, are those level surfaces of ions in the video?
Liam David
It's the density of D2+ ions on the domain.
Liam David
I've rewritten much of the code and have fundamentally changed the data storage architecture to reduce memory operations, resulting in about an order of magnitude speedup especially at large particle counts. The precision has also been reduced from double to single.
I have also focused on maximizing the performance of collisionless particle tracking, meaning simulations of several million particles evolving for several milliseconds are possible with an overnight run (with a timestep of 40ps). A common performance metric for PIC codes is particle push/boundary check operations per second, and mine achieves ~10^10/s on an RTX 3080, or very roughly 600 GFLOPS. It's a memory-limited application, so the raw FLOP performance does not come close to the maximum of about 30 TFLOPS.
Other changes include:
  • Implementing a 5-point stencil (instead of a 3-point) for the Laplacian in the electric field solver, and making it fully applicable to cylindrical coordinates by including the 1/r*df/dr term. It now accurately produces the logarithmic potentials found in cylindrical geometries.
  • Adding magnetic fields, which is accomplished by providing a magnetization density vector field M and solving a Poisson equation much like the electrostatic case. Some preliminary simulations indicate that a moderate axial magnetic field can enhance ion lifetime, as well as the phase space of stable and quasi-stable orbits. The Boris algorithm is used to push the particles.
  • Accounting for collision angle in the fusion rate calculation (work in progress).
5-point Laplacian
5-point Laplacian
Magnetic field lines superimposed on electric potential
Liam David
As I hinted at before, the simulation reproduces the color bands seen on cylindrical cathodes, as well as the off-axis beams and circumferential ring bisecting the inside. Due to all the code changes, I can now simulate steady state, which constitutes ~8e6 total particles. I'm also getting hints of what may be ion acoustic waves (or transit time resonance) at ~13 MHz... I'm slowly building confidence in the simulation, although the calculated locations of fusion reactions are not where expected, as in not within the cathode due to anomalous electron trapping. More results to come.
High density beamline obscured to enhance contrast
Javier Lopez
Real name: Javier L
Post by Javier Lopez »
Can you set external magnetic fields in your simulations?
With all those posts and you still not using your full name either you are intentionally breaking the rules or feel you are above them. I'd suggest you follow the rules here if you want to continue posting.
All of the posts by "fusion" will be deleted if he doesn't change his user name along with any responses to his posts.
Frank Sanns
Real name: Frank Sanns
Post by Frank Sanns »
Negative. Do not delete Javier's posts.
He has been on here for over a decade but has just come back after the rule changes.
Give him a chance to respond. I have sent him an email but I do not want to change his login name as it will prevent him access.
Under no circumstances should we be nuking somebody with over 100 posts. It is not good form and it will screw up over 100 threads.
Can we go back and un pink all those posts? I do not know how to do it.
Return to “Advanced Technical Discussion Area”
