Aidan, youthful wisdom suggesting cooling the jets. Thanks once again. The only side to take is the one of acceptance of all views without rancor. Amateur fusion is the mission here whether one is dirt poor or a millionaire, so long as it is an amateur effort, self-funded, self-assembled and operated. We are open source. No secrets. Open sharing of tech, operational techniques and quantified results with full imaging of kit and related hardware are expected. This has always been the stomping and proving ground for "doers", past and present. One hopes for the future as well.
What are we doing here?
Re: What are we doing here?
- Real name: Andrew Seltzman
To respond to Franks initial post:
I don’t feel the recent operational fusor audit was meant to exclude anyone, just to get a general feel for how many of us still have operational systems, not just one-and-done fusors that demonstrated neutron output and were subsequently dismantled as people moved on to new hobbies. Neutron activation was just a benchmark of a “reasonable output flux”, and one hour was a “reasonable operational time”. I would personally consider any system that can be turned out and demonstrate neutron flux as an operational fusor.
Scintillator/oscilloscope, BF3 tubes with a removable moderator, He3 tubes, Bubble detectors, activation, beta spectroscopy are ALL acceptable means to prove fusion. Bubble detectors have been chosen by some to demonstrate (especially with lower output fusors) that actual neutron production is occurring, not just noise pickup; their dose integrating nature allows long duration runs at fluxes where a BF3/He3 tube would not provide accurate counting statistics. My first demonstration of fusion was with a bubble detector for just this reason (operating in the ~15kv range), while now with much higher output flux a BF3 tube will easily demonstrate neutron production in my fusor. There is nothing wrong with using one method over another as long is the demonstration of neutron production is clear and the detector and counting statistics are well matched to the neutron flux and signal to noise ratio.
With improved technology, surplus equipment, and understanding of neutron generator technology, the logical urge is to push to higher neutron numbers. Whether by “IECF”, beam on target, pinch, etc... The progress in increasing neutron output continues, as it should. Sure, beam on target is used commercially, but so what, we are an amateur group building neutron generators for fun as a hobby. While IECF was the initial focus of this forum, this was more of a historical occurrence starting with the 1998 Tom Ligon article and Richard Hull’s fusors that kick started armature neutron production as a hobby. Fusors are just more showy as you can see the plasma, though it could just as easily have been a dominantly beam on target hobby but for a flip of a coin on the neutron generation method in that fateful article in 1998.
Absolute flux is a good benchmark. I don’t think separating out into separate beam-on-target, pinch, groups would be productive or necessary. If people can and want to get higher flux with beam-on-target, good on them. Anyone who unambiguously demonstrated “neutron production” (no requirement on flux, just a positive confirmation) should be a member of the neutron club. Likewise, any neutron producing device should, for the purposes of neutron club membership or classification as an “operational fusor”, be accepted. The addition of new and novel designs such as the cube fusor, beam on target, and other designs have pushed the neutron rate to higher levels and fostered technological innovation.
I strongly oppose restricting to, or even implying that, this forum should be IECF based, in the main, because an “IEC fusor” does not have a distinct neutron generation mechanism within the realm of plasma physics. The Hirsch-1967 spatial distribution of fusion neutrons inside the cathode that was originally attributed to virtual electrode formation (poissors) was actually due to beam-on-target effects. The SIGFE experiment at UW Madison demonstrated over a decade ago that the majority of the neutrons produced in the Hirsch-1967 fusor were in fact produced by beam-on-target fusion with the interior surface of the cathode, in addition to beam-on-beam and beam-on-neutral fusion outside the focal point. https://iec.neep.wisc.edu/usjapan/13th_ ... chalak.pdf
The salient findings were:
- Less than 0.2% of the D-D fusion reactions are from center of SIGFE device
- Virtual potential well structures and other space-charge related physics at the center of the SIGFE cathode are not a significant source of fusion
- D-D and D-3He fusion protons observed from center are consistent with beam-background fusion
- The results of the SIGFE imply that beam-embedded fusion in the cathode lenses is the dominant D-D fusion mechanism in the SIGFE
Andrew Seltzman
www.rtftechnologies.org
Great post Andrew! The salient points you outline are certainly correct in every respect and not only from our findings but those of others from academia. For me, and long stated in the Neutron club information is the statement that all forms of proven fusion will make news and be accepted here. Paul formed this entire venue back in 1998 for Folks to discuss and experiment in the Farnsworth fusor concept, and fusion in general. I was attracted to the process as a possible source of neutrons for experiment. Others have come and gone and contributed over the years for their own reasons. I feel this is what this forum is all about.
What you put into it is what you get out of it for as long as you wish to be here, for your own reasons, using your own initiative, and in a manner that teaches you something and that you share and are willing to teach and assist others.
A large number have come here to compete against others or even themselves. That is fine if it pleases them. The real winners, of course, are the doers, the learners and the teachers who have come and gone as well as those who remain, and those who will arrive in future in search of some goal that only they can define from their own perspective.
