The LM35 is a temperature sensing chip.
My supply of genuine TI brand LM35's is running out, and although this chip is still available from the far east traders, I would prefer genuine samples, if for no other reason, then to be absolutely sure that I get the 150Deg. C. Version, instead of the 100deg. Variety.
Digikey, Mouser, Farnell, RS Components all are out of stock, with no indication of a restocking opportunity, other vendors simply state, the part is no longer stocked.
TI still list the item as in production.
Anyone here close enough to TI to tell if this is true?
The TO220 variety of the LM35 is the only one that is immediately usefull to me, whereas the other package options require custom heat transfer interface hardware to be manufactured.
Cheers, Finn Hammer
LM35 TO220 Version discontinued?
- Finn Hammer
- Real name: Finn Hammer
- Bob Reite
- Real name: Bob Reite
Re: LM35 TO220 Version discontinued?
You can still order it from Mouser. Part number if LM35DT/NOPB for the TO220 case
I checked siliconexpert and there are LM35s that have 10 year plus life cycles.
https://docs.google.com/spreadsheets/d/ ... ue&sd=true
I checked the part number Bob gave by mouser and they have thousands on order with an expected delivery date of March 2023. None in stock of course.
Whatcha' wanna' bet they will be ChiCom manufactured...lead time to set up fab.
- Bob Reite
WOW! Someone must have bought the last stock. The time that I looked, they had about 500 available for immediate shipment.
How odd Bob. You mention about 500 remaining LM35s coincided with your 500th posting. I thought I heard the twilight zone 4 bar music in the background.
