Hello fusors,
Is there a post regarding how to get the fusor parts ( Parts Brands).
is there proposed website or application I can find all these specialty items.
i want to buy the flowing with the proposed best Brands:
1- High Voltage Feedthrough with Tungsten inter connected -ve electrode
2- 2-Stage Vacuum Pump
3- Turbo-particles pump
4- Vacuum Pressure Gage
5- Vacuum chamber, Flanges and View port thic Glass flange.
6- High Voltage 50K VAC transformer
7- J-B Weld Glue
8- D2 Deuterium Gas in Cylinder
9- Neutron bubble detector.
10- Electric circuit to achieve 20K V DC
please help and support
Worm Regards
Ali Bukhamseen
is there a post regarding how to get the fusor parts
- Real name: Ali Bukhamseen
- Real name: Frank Sanns
Re: is there a post regarding how to get the fusor parts
There is an entire section dedicated to it at the top of the TRADING POST portion of the forum. viewforum.php?f=75
- Real name: Victor Gonzalez
I get the feeling that money is not a problem and you prefer new over used parts, if that's the case see below:
A- High Voltage Feedthrough with Tungsten inter connected -ve electrode
B- 2-Stage Vacuum Pump
C- Turbo-particles pump
D- Vacuum Pressure Gage
E- Vacuum chamber, Flanges and View port thic Glass flange.
F- High Voltage 50K VAC transformer
G- J-B Weld Glue
H- D2 Deuterium Gas in Cylinder
I- Neutron bubble detector.
J- Electric circuit to achieve 20K V DC
Item A-> https://www.lesker.com/newweb/feedthrou ... id=20kv_cf
Model EFT6012156
Items B and C - > https://www.idealvac.com/NEW-Edwards-T- ... pp/P109248
Items E -> https://www.idealvac.com/6x6x6-Cubic-Mo ... pp/P109151
https://www.idealvac.com/HVA-CF-Conflat ... pp/P104198 or https://www.idealvac.com/IVP-Super-Seal ... pp/P103843
https://www.idealvac.com/Flow-Metering- ... -1489-1582
https://www.idealvac.com/Fittings-and-Flanges/ct/2
Item D -> https://www.idealvac.com/Edwards-Packag ... p/P1010191
Item F and J-> https://www.spellmanhv.com/en/high-volt ... pplies/SLM
Model SLM50N1200
Item G-> Shouldn't be needed
Item H -> https://www.sigmaaldrich.com/BR/pt/prod ... ich/368407
Item I -> https://www.crystals.saint-gobain.com/p ... -solutions
G- J-B Weld Glue
Model EFT6012156
Model SLM50N1200
Dears,
Thank you very much for your quick response and support
I really appreciate that.
Thanks
Ali Bukhamseen
Thanks
Ali Bukhamseen
Hi team,
Some of the items are a hell lot expensive.
I am not planning to buy any component more than 1000 $.
If there is a links for used or second hand, it will be fine.
I appreciate your support.
Regards
Ali Hassan
Regards
Ali Hassan
