High current, low voltage feedthrough?
RobertMendelsohn
Real name: Robert Mendelsohn
Post by RobertMendelsohn »
(feel free to move this if it's of sufficient interest to merit a permanent record, since it's not fusion related)
Hello all!
I am building a [vacuum] thermal evaporator, and need to build high current (100-300A) but low voltage (0.5-2V) feedthroughs.
Most fusioneers have all the parts they need to build these devices, minus the aforementioned feedthroughs; does anyone know an easy way to fashion them?
Initial ideas:
  • * 0.25" copper rod through a 0.25" swagelok (what about insulation?)
    * silver braze copper rod through a stainless steel blank
The usual spark plugs don't seem to work due to the current and voltage requirements (i.e. too high of a resistance). Does anyone have a good idea?
Sincerely,
Robert
JoeBallantyne
Real name: Joe Ballantyne
Re: High current, low voltage feedthrough?
Post by JoeBallantyne »
Conflat versions of high current vacuum feedthroughs can generally be found pretty easily on ebay for about a hundred dollars.
Simplest solution would be just to buy one.
Joe.
JoeBallantyne
For example : https://www.ebay.com/itm/274808213225?h ... SwtXNgqtZJ
He will consider best offers and the shipping is free.
I bet you could get it for $68-72. Maybe even less.
Joe.
RobertMendelsohn
Hi Joe!
Thank you for your answer - I will do that.
Thanks again,
Robert
JoeBallantyne
You can actually get brand new high current feedthroughs for under $100.
For example: https://mpfpi.com/shop/power-feedthroug ... 0049-1-cf/
Joe.
