MFC fitting identification help!
- Real name: Robert Mendelsohn
Hi, I have a MKS 1259C mass flow controller and I'm trying to ID the fittings (photos below).
I (very naively) saw that they were listed as VCR4 and I order a VCR4 to KF40 adapter, but they do not mate.
They appear to have the same IDs, ODs, etc. but the threads of the female to not reach the male thread.
It also appears as through the male end (attached to the MFC) does not have the right geometry to accept a gasket.
I have two ideas, but would really appreciate the help of someone who knows what I am screwing up before I spend a bunch of $$$ on more parts...
Idea #1: MFC actually is NPT, so I need to get an NPT to VCR4 adapter (body?)
Idea #2: the MFC side is supposed to connect to a Swagelok gas pipe or some other fancy thing.
Any and all ideas appreciated!
Sincerely,
Robert
Note: the main thing to point out is that the inside of the connection on the MFC side is tapered in.
Sincerely,
Robert
Re: MFC fitting identification help!
1/4" Swagelok compression (missing ferrule and cap)
Thanks Joe! You're a lifesaver. Pardon the elementary question, but what all do I need to order to get it working/mated? A ferrule, endcap, and a gasket?
No gasket ... the ferrule serves this purpose. What you need depends on what you are connecting it to ... take a look at Swagelok's website. But in the absence of more details, something like https://www.ldsvacuumshopper.com/nw16to14tubeod1.html, ferrule, cap, and copper tubing.
Hi Joe, thank you for the information, I will read through their site/catalog/etc.
I am trying to connect the MFC on the left with the adapter on the right.
Allegedly, the MDC is VCR4 and the adapter is VCR4 to KF40, but it doesn't work, naively.
That's not going to work. You need a Swagelok compression to VCR adapter.
SS-4-VCR-6-400 — 316 Stainless Steel VCR Face Seal Fitting, Swagelok Tube Fitting Connector Body, 1/4 in. VCR x 1/4 in. Tube Fitting, with a length of 1/4inch tubing.
You can use the flange adapter from LDS vacuum (previously linked) instead. If you go the VCR route make sure you get the metal gaskets for the VCR portion.
Thank you Joe! I bet you can tell I am really lost on this one...
More broad question: what do you think is the cheapest/easiest way to connect that MFC to a KF40 piece?
KF40 to 1/4in Swagelok compression adapter and a length of tube
Adapters keep a lot of brother-in-laws of fitting manufacturers in business and help put their kids through college. Fitting manufacturers do a great job of creating novel and very different fittings only because they what you to by their stuff. To them, their stuff is the greatest. Manufacturers of vacuum active components often figure the same way and figure why use some sort of standard fitting if we can design our own and keep it all in house? Oh, they may offer standard fitting models but at an increased cost. If you aren't going to use their fittings, they will get a bit extra from you up front.
Now the above is very cynical, but the list of what might be called industry standard fittings is a long one! An amateur buying off of e-bay will always keep the brothers-law in the adapter business happy and well remunerated for desperately needed adaptation for "this" standard fitting to "that" standard fitting. The vacuum catch-22.
Thank you everyone for your help - this ended up working nicely. Used 1/4" copper refrigeration tubing, got Swagelok compression nuts and ferrules. Now have a great mass flow controller working, all for about $100!
Thanks again!
Thanks again!
