Olive compression fittings in High Vacuum
Posted: Sun Jun 20, 2021 6:36 pm
by Albert Mery
Hello all,
So I am beginning to plan the construction a HV feedthrough and I was hoping to use regular olive compression fittings used in plumbing. I know that Swagelok fittings would be ideal but I don't have access to any such fittings ( due to the long shipping times from China or the US). So I was wondering whether anyone had any experience with using olive compression fittings in High Vacuum? I'm also planning to use them with quartz tubing and I'm not sure how tight the fit will be...
Thanks in advance!
Albert
Re: Olive compression fittings in High Vacuum
Posted: Mon Jun 21, 2021 6:01 am
by John Futter
Albert
Olive fittings they may or not may not work for high Vacuum --ie a very possible leak site
Swagelok have special weld on fittings that get rid of the olives for high vac work.
their other branch sells VCR fittings for high and ultra high vacuum work
Posted: Mon Jun 21, 2021 12:13 pm
by Joe Gayo
Use orings.
Posted: Mon Jun 21, 2021 12:49 pm
Like already stated, Swagelok is more than suitable for the small gas lines in fusor work. VCR is vastly More expensive, but a must have for those working in very deep vacuum systems where larger lines are the norm.
Posted: Wed Jun 23, 2021 10:16 am
by Albert Mery
Thanks for the advice, I will look into purchasing some VCR fittings...
Joe, how would I make sure the o-rings maintain a tight seal? Alternatively do you think it is possible to braze alumina onto stainless steel?
Posted: Wed Jun 23, 2021 1:32 pm
by Mark Rowley
Since you are going to use quartz tubing, perhaps this can help:
viewtopic.php?f=10&t=13782&p=89853&hili ... ect#p89853
I just made another a couple days ago for the tube furnace project and they easily allow for vacuums well below 1mTorr.
Posted: Thu Jul 08, 2021 9:24 pm
by Joe Gayo
Brazing is a delicate art/science. The alumina would need to be metalized with MoMn or TiW. I would look at older books on vacuum tubes, such as Materials and Processes of Electron Devices by Max Knoll (amazing book) on how to join insulators and conductors.
Orings are extremely versatile and could be implemented in a number of ways. A properly sized oring could replace the ferrule, but I don't recommend this. Something along the lines of a conical or radial seal would be best. I think Mark has a number of parts constructed this way and I would look at the post he suggested.
Posted: Thu Jul 15, 2021 1:55 pm
by Albert Mery
Thanks for your helpful indications. I opted to use orings as you suggested in conjunction with some KF25 parts. The centerpiece of the feedthrough is a high voltage standoff through which I will bore a small hole for the conductor. The orings fits tightly around the ceramic stand off and seems to offer a fairly good seal. It was able to hold my vacuum pump's ultimate pressure with no problems however I have yet to test the setup with a sub-micron vacuum or a high voltage so I cannot say yet whether or not it is a success...
Does anyone have any tips for drilling through ceramic?
Posted: Thu Jul 15, 2021 2:10 pm
by Joe Gayo
Looks like a good direction. You might want to add a metal ring that fits around the OD of the oring, but is thinner than the cross-section of the oring (an "overpressure" ring might work). This way the oring can't squish out too much and it's forced to seal to the flange and ceramic. That would be more of a proper radial seal (look at the Parker oring handbook)
Depending on the ceramic, a diamond drill bit might work. How do you plan on sealing the conductor to the ceramic? (a oring is an option here as well, but you will need a smooth surface on the ceramic to seal to) I would recommend a ceramic sealing cement (used with vacuum tubes and light bulbs). Again look at Materials and Processes of Electron Devices by Max Knoll for ideas.
I've not tried this but
https://www.mcmaster.com/7482A11/ might work to seal the conductor to the ceramic.
Posted: Thu Jul 15, 2021 2:23 pm
Great for a demo fusor at 5-10kv, as would be a common spark plug of some special order type. I used a common ford spark plug for my early demo fusors. an a special formula one plug for my water arc explosion guns back in the 1990's.
A tour through the AC Champion special plug lineup would produce some interesting plug types, up to about 20kv or more.
Posted: Tue Aug 03, 2021 6:17 pm
by Albert Mery
Hello Joe, Richard,
Thanks for that advice about the metal ring, I made a crude one with some metal scraps and a small spring. I was planning on using Shellac to create a vacuum tight seal for the conductor... however I haven't gotten that far saddly. I have been completely unable to drill through this ceramic. The diamond drill bits were only able to bore a couple millimeters after 20 minutes of drilling with water
. If I had a lathe I'm sure it could be done easily but that's not quite in my budget. There are so many knowlegeable craftsman on this forum, I was wondering if anyone had any tips and tricks on how I could get this done? I might just scrap this hole standoff idea all togethere and opt for a Liam David type feedthrough. As Richard mentioned, even if I got it working this feedthrough it would only be good for demo fusor use...
Albert
Posted: Tue Aug 03, 2021 8:19 pm
by Joe Gayo
The quality of the drill bit, cooling, and setup matter a great deal. Can you find another ceramic piece that already has the through-hole? Otherwise use a spark plug...
