Hello Joe, Richard,
Thanks for that advice about the metal ring, I made a crude one with some metal scraps and a small spring. I was planning on using Shellac to create a vacuum tight seal for the conductor... however I haven't gotten that far saddly. I have been completely unable to drill through this ceramic. The diamond drill bits were only able to bore a couple millimeters after 20 minutes of drilling with water . If I had a lathe I'm sure it could be done easily but that's not quite in my budget. There are so many knowlegeable craftsman on this forum, I was wondering if anyone had any tips and tricks on how I could get this done? I might just scrap this hole standoff idea all togethere and opt for a Liam David type feedthrough. As Richard mentioned, even if I got it working this feedthrough it would only be good for demo fusor use...
Thanks,
Albert
Olive compression fittings in High Vacuum
- Real name: Albert Mery
Re: Olive compression fittings in High Vacuum
The quality of the drill bit, cooling, and setup matter a great deal. Can you find another ceramic piece that already has the through-hole? Otherwise use a spark plug...
