Bonjour from Washington State
Locked
Jean Paris
Real name: Jean Paris
Post by Jean Paris »
Hi,
My name is Jean and I was born in France but I moved several years ago in Washington state.
I am interested in fusion since high school (more than 10years ago). Back then I had no idea of the physics behind but I started to build a VdG generator and I bought a 25€ vacuum pump. Of course, the vacuum pump was not powerful enough and my VdG just did some nice sparks but that’s it.
After I moved for my engineering study far my experiment garage... But I studied a little bit fission nuclear physic but I mainly followed a completely different path.
Last year, I found again a book of JL Bobin that I bought very long time ago and this book triggered again my full attention to fusion.
First I need to refresh my memory on particle physic and next step is to build a fusor or a ion gun that works not like my first attempt...
Talk to you soon!
J
Real name: Dennis Brown
Re: Bonjour from Washington State
Post by Dennis P Brown »
Bonjour (not that I speak French but my daughter is fluent.)
Knowning particle physics is not in any manner required nor really needed. The particle physics required is easy to pick up in fifteen minutes of reading on the wiki. However, learning more on particle physics is, just in its self, useful so certainly do that if interested.
Building a simple ion gun is certainly a great learning experience and vastly easier and a fair bit (depending on its complexity) less costly than a fusor. Further, it need not use lethal voltages or generate dangerous x-rays (like fusors and high end ion guns - the key is voltage.)
Best of luck in your studies and future reserach ideas.
Jean Paris
Thanks for your reply! Your daughter picked up one on the most difficult language... good luck for her
I need to understand a little bit what is behind when I build something... But yes, I am here to learn^^
Locked
Return to “Please Introduce Yourself”
