"The first rule of membership in these forums is: you must create your account using your real, full, first AND last names as the LogIn/UserID for your account. If your name is John Smith, your UserID (i.e. login handle) must be John Smith, or John_Smith."
I belive you should change your username to comply with the forum rules. Not trying to be mean, Its a common mistake, but one that needs to be fixed.
Otherwise, welcome to the forum, make sure to check out the FAQs for all the knowledge that you need!
Hey Guys! Im newbie
- Real name: caden burkhardt
Re: Hey Guys! Im newbie
I am assuming this is a warning from Caden to someone who has been purged and is now out floating in space here. I will delete all soon.
