FAQ: Complete fusor diagram
Go to the location below for a more complete FAQ
viewtopic.php?f=24&t=2674&p=12184#p12184
Re: FAQ: Complete fusor diagram
Most all fusioneers never use a "fore-line trap". It is part of any real professional system and is included as an "ideal" item to have in a vacuum system.
The trap is there to keep mechanical pump oil vapor out of the secondary pump. The secondary pump is either a diffusion pump or a turbo pump.
I am attaching a fusor vacuum system image of the type most often used today. Some people do not use a diffusion pump and replace it with a more modern turbo-pump. You must have one or the other in addition to the mechanical pump.
Return to “FAQs: Fusor Construction & Operation”
