Joshua Turbyfill - Store - For Sale
Use this forum to offer items for sale.
Joshua Turbyfill
Real name: Joshua Turbyfill
Post by Joshua Turbyfill » Fri Jan 31, 2020 6:26 pm
Heres a list of everything I have for sale at the moment. Feel free to PM me for any questions.
I also have an assortment of HV wire, BNC cables, new conflat copper gaskets, and conflat bolts. PM me for more info.
Conflats
2.75 Conflat 5-Way Cross - $200 SOLD
(x2) 2.75" CF Manual Right Angle Bellows Valve - $135 each ONE LEFT
8" Conflat Blank - $140
6" Conflat Blank - $85
2.75" Long Tee - $60
2.75" Pipe - $50
2.75" Elbow -$40
CF2.75" x KF25 - $70
CF2.75" x Female 1/8 NPT Blank - $40
(x2) 2.75" Blank - $17 each
Vacuum Gauges & Valves
(x2) Pfeiffer TPR 265 Pirani Gauge (Both tested, one has small crack on frame) - $120 each
Swagelok 1/2" NPT Needle Valve - $50
D-PRO 1/4" NPT Needle Valve - $30
Whitey 1/4" OD Tube Thermal Service Ball Valve SS-63TMS4 (Green Handle) - $25
Misc. Large Items
Civil Defense Complete Radiation Detection Kit + CDV700 Rebuild Kit + CDV700 Speaker - $150
Pittsburg Automotive 3 Cfm 2 Stage Vacuum Pump (New - open box minus oil) - $100
+/- 0-3 KiloVolt Power Supply (Works but has one issue, dm for more info) - $90
Sample Cylinders:
Swagelok 304L-HDF4-1000 Double Ended Sample Cylinder (1/4 NPT) - $150
Whitey 304L-HDF4-500CC 1/2 Liter Cylinder + Nupro SS-4H-W1J Shutoff Valve - $75
KF and ISO Flanges
ISO100/DN100 Centering Ring with aluminum protective screen and multi purpose coating (NEW) - $50 each
KF16 4-way cross aluminum - $40
(x16) ISO Double Claw Clamps (Works on ISO63, ISO100, and others) - $40 for the lot
KF25 Clamp + O-ring with protective screen - $35
KF25 x 1/2" NPT - $22
(x2) KF10 Clamp + O-ring + Blank off cap - $18 each
(x5) KF16 Clamps & O-Rings - $6 each
NPT & VCR Connections (ALL SWAGELOK)
1/4" VCR Flexible Hose 22.5" - $30
1/4" Female to Female VCR - $30
1/2" Female VCR x 1/2" Female NPT - $30
1/2" Female VCR x 1/4" Male VCR - $30
1/2" Female NPT x 1/4" Male NPT - $30
1/4" NPT x 1/16 OD Tube - $30
1/4" Female VCR to 1/4" NPT - $23
(x2) 1/4" VCR Male Elbow - $15 each
1/4" Female NPT Tee - $15
(x2)1/4" NPT x 1/4" NPT Nipple - $13 each
1/2" NPT x 1/8" NPT - $13
1/4" NPT Female to Female Elbow - $12
1/4" NPT Male to Female Elbow - $12
(x3) Brass 1/2" NPT x 1/4" FNPT Reducing Bushings - $12 for the lot
1/8" OD Tube Plug - $7
Re: Joshua Turbyfill - Store - For Sale
Post by ian_krase » Sat Feb 01, 2020 9:16 pm
Can you give details on that flex hose?
Joshua Turbyfill
Post by Joshua Turbyfill » Sun Feb 02, 2020 5:52 pm
Its a Swagelok FM4 316L stainless steel braided hose with a male 1/4" VCR connector at one end and a female 1/4" VCR at the other. Its in like-new condition, and its about 22 1/2 inches from end to end. Its rated to 3100 PSIG.
Post by ian_krase » Thu Feb 06, 2020 9:17 am
"Braided stainless" = stainless braid over corrugated stainless flex hose, right?
How flexible?
Joshua Turbyfill
Post by Joshua Turbyfill » Fri Feb 07, 2020 1:51 am
Swagelok says its "constructed of stainless steel for minimal permeation or absorption. The convoluted [metal] core allows for flexibility, and limits kinking. Suitable for high-temperature, vacuum, medium-pressure, corrosive or general-purpose environments." (https://www.swagelok.com/en/product/Hos ... less-Braid)
Its pretty flexible.
Jim Enright
Real name: Jim Enright
Post by Jim Enright » Tue Oct 13, 2020 1:12 am
I know that your post is from over 8 months ago, but do you have any of these items still available? Thanks!
“Whether you think you can, or you think you can't – you're right." Henry Ford
