Photodiode Pulser Circuit
Members may post files they wish to share here.
Richard Hester
Post by Richard Hester »
Attached is a short page describing a photodiode pulser that can be used to test charge sensitive and other preamp circuits. Using this pulser, one obtains accurate results for charge sensitive amplifier fall time. The circuit is a touch slower than a PMT, but a whole lot easier to build and power, and smaller to boot. Any fast photodiode could be used in place of the SFH203 cited in the schematic.
Photodiode_Pulser.PDF
(15.69 KiB) Downloaded 507 times
Joe Gayo
Real name: Joe Gayo
Re: Photodiode Pulser Circuit
Post by Joe Gayo »
Does anyone have this file?
Post by John Futter »
I do not know about the original file but I use this one to test SPIMs and PMT's
photopulser.pdf
(2.2 MiB) Downloaded 557 times
Note it uses a very high voltage to get the necessary dI/dT through the blue LED
Jon Rosenstiel
Real name: Jon Rosenstiel
Post by Jon Rosenstiel »
Fixed the missing file, should work now.
JonR
Return to “Files”
