XFMR Coupled Pulsed Fusor
Members may post files they wish to share here.
Richard Hester
Post by Richard Hester » Thu Mar 21, 2002 6:42 am
Attached is a possible simplified schematic for a pulsed fusor using a step-up pulse tranformer to allow use of thyratrons and storage capacitors of relatively low voltage rating. It was assumed in this case that the primary magnetizng inductance of the pulse transformer was relatively low, so that it could double as the charging return inductor. If this is not the case, a charging return inductor could be placed across the transformer primary. Food for thought and grounds for further research....
