Archived - European Fusor
Andrew Robinson
Real name: Andrew Robinson
Re: Archived - European Fusor
Post by Andrew Robinson » Tue Nov 04, 2014 7:00 pm
About what I expected. Thanks!
Werner Engel
Real name: Werner Engel
Post by Werner Engel » Fri Dec 12, 2014 9:23 pm
Today we started to stick the first parts together.
The doublecross is DN100.
The windows are not AR coated yet, but will be ...
Post by Richard Hull » Sat Dec 13, 2014 11:56 am
Wow! This is gonna' be a big boy! Wish I had a piece of chalk. ( there is a back story) As I am also a model railroader there is a real story about the Union Pacific Railroad ordering the largest locomotive ever made in a fleet of these steam locos in the early 40's. As the first one of these million pound + locos rolled out of the builder shops, some unknown worker took a big piece of white chalk and wrote in big foot tall letters on the front smoke box cover... "Big Boy"... The name stuck and that group or class of engines acquired that worker's moniker for all time.
This fusor is truly going to be a big boy among fusors, once it is lit up!
Adam Szendrey
Real name: Adam Szendrey
Post by Adam Szendrey » Sat Dec 13, 2014 3:56 pm
Wow, that is a beautiful, big, clean system you are building there! Love the large windows. Can't wait to see it in action! Just checked out your introduction, nice to see someone so close to me (I live near Budapest), building such a wonderful fusor. Maybe one day I'll hop over and take a look :). Eventually we'll have fusion cons around here! (unless I missed it and there already are happening, which is perfectly possible considering how I've been out of the loop!)
Ps.: That HV feedthrough with the massive insulator made me drool!
Last edited by Adam Szendrey on Sun Dec 14, 2014 9:05 am, edited 2 times in total.
Frank Sanns
Real name: Frank Sanns
Post by Frank Sanns » Sun Dec 14, 2014 4:35 am
Very nice but I would need two insulators. $$$$$ :-(
Werner Engel
Re: Archived - European Fusor - HV-PS
Post by Werner Engel » Tue Apr 28, 2015 6:15 pm
Hi friends of the high voltage!
My new HV-transformator just arrived!
Here some data:
30 kV
2 kVA !!!
about 60 kg of material ;-)
including a thermal circuit breaker adjusted to 75°C.
This will create about 42 kV DC at approx. 50 mA - I love it!
If it's not enough, I can add another one reaching 84 kV - but this seems to be toooo much!
Four of them would reach the voltage for p-B11 :-)))
No, I'm kidding!
I will test it this Friday - whish me luck.
Post by Rich Feldman » Tue Apr 28, 2015 7:27 pm
Good luck with that transformer, Werner. :-)
Did you have it made to order, or was it designed for something else?
What are all those primary taps for?
Will it be used under oil?
Werner Engel
Post by Werner Engel » Sat May 02, 2015 3:00 pm
OK, I had bad luck!
Unfortunatly, after just reaching 18 kV, we had an arc between the HV coil and the core.
End of the story - I will try to let it repair on monday.
Isolation has to be improved or I have to submerge it in oil - what I tried to avoid.
Here you see two pics showing the corona discharge close to the rectifier diodes (in the darker picture) and the whole setup (built together with Philipp).
@ Rich: The primary taps are to pre-adjust voltage.
Werner Engel
Post by Werner Engel » Thu May 14, 2015 3:40 pm
OK, here is the solution to my last problem:
The Isolation at the bottom of the HV coils was optimized with this black isolation resin.
Should work now!
I'll keep you informed.
Werner Engel
Post by Werner Engel » Thu Sep 14, 2017 6:53 pm
Hi friends of fusion!
Within the next weeks I will travel to ITER.org together with some Austrian scientists. We will have a Special tour and also meet some of the guys working at the superconducting components. Pictures will be available in October.
Her ist an actual picture of my new CF double cross ready to be connected to the turbo. The old Iso-KF thing has to go ...
BR,
Werner
PS: Please also have a look at my invitation to the "European Fusor Meeting" viewtopic.php?f=47&t=11622
