Archived - Plasma fusor
Liam Foyle
Real name: Liam Foyle
Post by Liam Foyle » Sat Aug 31, 2013 1:46 am
Here pictures of my demo fusor the vacuum isn't perfect but it still makes plasma.
Carl Willis
Real name: Carl Willis
Re: Plasma fusor
Post by Carl Willis » Sat Aug 31, 2013 2:55 pm
That's a good start, Liam. Congratulations!
What are you planning to do next?
Carl Willis
TEL: +1-505-412-3277
Liam Foyle
Re: Plasma fusor
Post by Liam Foyle » Tue Sep 03, 2013 12:27 am
Thanks! Would I be able to join the plasma club?
charlie_mccartney
Real name: Charlie McCartney
Re: Plasma fusor
Post by charlie_mccartney » Tue Sep 03, 2013 1:15 am
Quick question, how did you connect your vacuum.
Charlie McCartney
charlie.mccartney1104@gmail.com
charliespersonalproject.weebly.com
Re: Plasma fusor
Post by Rich Feldman » Tue Sep 03, 2013 4:27 am
Liam,
I am not the judge here.
If I were, would expect more than a picture (which you could have found anywhere).
If you can make a plasma, you ought to be able to effectively tell the story.
To Richard Hull: are the req's for plasma club codified as clearly as those for neutron club?
How about a few words about the power supply. Is it adjustable? Is it DC? What polarity? Any measurements?
How about the vacuum system. How connected to chamber? Can you adjust the vacuum? Have you measured it? Does the plasma go out if you run the pump long enough?
Tell us more about the chamber. What vessel? What are you using for a feedthrough? What are the curly wires made of?
Thanks! I hope we hear more from you.
-Rich
Re: Plasma fusor
Post by Richard Hull » Tue Sep 03, 2013 4:10 pm
Yes, some details would be nice.
Liam Foyle
Re: Plasma fusor
Post by Liam Foyle » Sun Sep 08, 2013 2:50 am
Thanks people for all the support and help!
My fusor is powered by a -3000v rectified dc nst, and has a 3 cfm rotary vane vacuum pump.
Liam
