Wyatt;
how did you bore the hole for the view port in the SS Bowl and what are you using for the view port. Great work for low budget. Larry Upjohn.
Archived - Kitchenaid fusor first light
- Real name: Larry Upjohn
Re: Kitchenaid fusor first light
Larry Upjohn
Thanks Larry,
The metal shop teacher used what I believe is a plasma cutter to drill the hole and the viewport is a 2- 3/4 kodial glass kf flanged viewport. I figured splurging on that was a good idea because i'd need it for a full scale fusor anyways.
Where did you get that particular shaped salad bowl ?
(And how much was it!)
It is a Kitchenaid Mixing Bowl. You can get them online for about $50: http://www.everythingkitchens.com/kitch ... 25NSF.html
