Archived - Fusor update
Andrew Seltzman
Real name: Andrew Seltzman
Post by Andrew Seltzman » Mon Aug 09, 2004 1:06 am
Well here is an update on my fusor construction. I have the turbo pump hooked up vacuum wise, however I still need a controller. I have designed a 3 phase VFD assembly that would drive the turbo pump correctly, however I am probably going to try to find an inexpensive controller for it first before trying to build my own.
My gas handling system is nearly complete, no that isn’t deuterium in the picture, its argon I had left over from my particle accelerator work. The gas handling system should be done in one or two weeks.
I have increased the height of the support stand and mounted the vacuum gauge on the stand itself. The gauge tube is now located at the reactor instead of at the vacuum pump.
By closing the valve between the reactor and the pump the pressure in the reactor will increase steadily, so it appears there is a leak that I did not catch earlier. I will have to go back to spraying ethanol on the connections. On the top side the turbo pump doesn’t leak.
On the other physics related front check out the updates on my website http://www.rtftechnologies.org . I have added a method for converting a CCD camera to a vertex detector.
Andrew Seltzman
Andrew Seltzman
