Archived - Fusor test pictures
Andrew Seltzman
Real name: Andrew Seltzman
Post by Andrew Seltzman » Thu Mar 25, 2004 4:16 pm
Here is a picture from my latest test. More are pictures are at:
http://www.rtftechnologies.org/physics/fusion.htm
This run is at -1.5kv.
Andrew Seltzman
(17.95 KiB) Downloaded 1722 times
Andrew Seltzman
Andrew Seltzman
Re: Fusor test pictures
Post by Andrew Seltzman » Sun Mar 28, 2004 11:17 pm
Here is the entire assembly
Andrew Seltzman
(56.18 KiB) Downloaded 1722 times
Andrew Seltzman
Andrew Seltzman
Archived - Fusor test pictures - update
Post by Andrew Seltzman » Tue May 11, 2004 6:46 pm
Here are the latest pictures from my fusor runs; the best vacuum so far is about 30 microns. The heavy copper spiral grid worked well at -6kv, however it melted shortly due to copper’s lower melting point. A new spiral grid is in construction.
Andrew Seltzman
(20.44 KiB) Downloaded 1722 times
(21.79 KiB) Downloaded 1722 times
Andrew Seltzman
Real name: Mark Rowley
Re: Fusor test pictures - update
Post by Mark Rowley » Tue May 11, 2004 9:49 pm
What was the diameter of your spiral grid ? The poisser looks much hotter and dense than in the traditional sphere grid. Are both photos operating at the same vacuum and voltage ?
Andrew Seltzman
Post by Andrew Seltzman » Tue May 11, 2004 11:51 pm
The spiral grid was 0.75” in diameter, vacuum: 50 mTorr, -6kv.
When run the spiral grid (1/8” OD copper tube) heated up until it was red and then melted. When it was cool the poisser was well defined.
The spherical grid is 1” in diameter, vacuum: 25-30 mTorr, -3.5kv.
The spherical grid (woven fine gauge platinum wire) will remain cool when run at -3.5kv but produces a fairly diffuse poisser. If run at -6kv the grid will become white hot but no poisser will be visible.
Andrew Seltzman
Andrew Seltzman
Andrew Seltzman
Fusor test pictures - update2
Post by Andrew Seltzman » Sun Jun 20, 2004 2:08 am
This is the new spiral grid. It is made out of a nickel-silver brazing rod. Grid voltage was -7.5kv, vacuum was 30mtorr.
At this stage ion beam damage was occurring. A solid shield panel has been added and ion beams are directed into it using steering magnets.
Andrew Seltzman
(11.76 KiB) Downloaded 1722 times
(23.95 KiB) Downloaded 1722 times
Andrew Seltzman
