Archived - Hull Fusor III setup
These three images show the bulk of the fusor III setup. The power supply controller is to the extreme left (barely in image). The x-ray supply is behind the danger high voltage sign below as well as the vacuum pump.
Two neutron counters of the BF3 type are seen to the left and right of the fusor chamber.
The video camera is positioned just to the right of the chamber and the image of the poissor displayed on the monitor in the upper right of the image. The small, homemade Lucite cased gieger counter in the foreground is used to sniff out x-radiation leaks.
The gas handling system is on the wall to the rear and the pressure gauge is just above on the wall.
The voltage and current digital indicators are just below the monitor self.
Return to “Images du Jour”
