That sounds like a ground/electronic shielding problem and probably isn't related to the x-rays.
If the discharge is unstable, then there will be high pulse current from the capacitors in the multiplier. The energy in the capacitors increases with the square of the voltage so the discharge current will be very high if there is an arc. Large current pulses produce magnetic and electronic interference that thin walled shielding will not effectively attenuate.
Is there any series resistance in the multiplier or between the multiplier and cathode? There should be! Even though the variac helps limit power, once the voltage is raised the multiplier can deliver significant energy.
Eastside Prep Fusor
- Real name: Gunnar Mein
Re: Eastside Prep Fusor
This is currently running with our 12 MOhm ballast. Yes, X-rays and trouble might very well be coincidental. I really do need to find you a recording what goes down in that scenario, though.
Like Joe, I am positive x-rays play zero role in your issues. I run my fusor on a 60 hz supply as well and just run full wave rectification at 40-45kv with zero filtering. I find any effort to filter even straight out of the high voltage transformer at 60hz in the fusor environment creates unwanted issues, as Joe notes. Just too much joule energy stored in any attempt to filter or smooth things out. Naturally, with a multiplier you must have the capacitance to multiply the voltage and therein lay the rub. The folks with HF switching supplies are more immune to this issue. A stable supply in the fusor arena in a must. Few, if any other devices, work in the region of gas plasmas and narrow, workable pressure ranges found in a working fusor. Thus, the power supply is critical.
RFI abounds in the fusor environment as a norm! However, it is manageable with good practices in place. With modern electronic monitoring and data collection systems using RF sensitive, low level signals entering sophisticated computers and microcontrollers, the noise riding on these signals will reset microprocessors or send them off to process nothingness, or lock up at critical data collecting times. In high joule pulses, the noise peaks can often destroy microcontrollers.
