CW, plasma, Paschen curve
- Real name: Gunnar Mein
Re: CW, plasma, Paschen curve
Gotcha. Typo in post. Fixed. Thanks!
Yes, floating and safely out of the way in oil the full doubler will function just not much current at the doubled voltage unless lightly loaded. As most fusors are metal shelled, this would not be possible in a real fusor due to all the vacuum plumbing and all attached instrumentation being at real electrical ground.
We tend to think fusion functioning fusor here when talking HV and safety. Safety grounds abound and there is only one viper to worry about.
A 60 Hz NST will never delivery any significant voltage and current for a CW that drives a plasma; once you hook it up to any real device to generate a plasma, the voltage will drop like a rock and the cap's will delivery very little current. Yes, a scope with its high impedance will show a different story.
None of this matters to join the plasma club! The device will ignite and hold a plasma so it will function for that purpose. Just don't lose sight of the fact that a VM for a real fusor requires a very high frequency driver circuit to deliver real current at a high voltage.
@Dennis, I don't know what else to say - we measured 32 KV across a 3.3 MOhm load, that works out to 10 mA for us. There was no high-impedance scope involved, just that load resistor and the actual divider boards we use in real scenarios.
We are going run an LTSpice simulation to convince ourselves that the lowside return on the CW is sufficiently standing in for the highside current. We don't see how it accounts for losses, but we would love not to do the whole optical link to the Arduino and stuff. When that's done, and we have a working current measurement, we'll gather all the evidence to apply.
Today and tomorrow, I am working with 7 students on a couple of improvements - camera under chamber, new 5V offset supply for divider board, maybe shielded cases for some electronics. I will post more pictures.
I went back to your introduction and you noted you have a "beefy" neon sign transformer. It would be great to know the name plate rating of your transformer. A stock non-beefy 15kv neon is rated at 30ma on the name plate. In the past, 15kv neon xfrmrs were made in 60ma and way back, 120ma current ratings. A 60ma version would support HV at a much higher current level and the very rare 120ma transformer would easily supply 20-30ma at nearly full voltage. Now that is beefy! Those ancient 120ma units were used to drive massive neon tube lengths in giant neon signage. Such signage is rare today and those massive hunks of iron have given way to custom designed electronic switching type supplies for modern neon. One day iron, shunted neon transformers will be talked about around campfires referring to the good old days.
I believe our NST is 15 KV peak-to-peak at 60 mA. Will try to find a picture of the plate.
That helps explain why you can get the 10ma. 30ma - normal, 60ma - beefy, 120ma - super beefy
The output current the the NST isn't the main issue here and I wasn't being clear - the voltage multiplier caps will determine the output power and at 60 Hz that isn't going to be very much. The caps are charging too slowly.
At 60hz all caps charge at the same rate, (assuming a suitable low impedance transformer), however 200pf caps will charge fully and not be able to support any real current at the multiplied voltage output of the multiplier. With 1ufd caps you will have far more energy to support high currents out of the multiplier. The hitch is that 1uf caps at 10kv are very expensive and rare. If you triple the voltage at 60hz with 1ufd caps, the net capacity is down to .33ufd when you need the current.
If you dream of 60hz multipliers, be ready to spend a lot of money for large capacitance, high voltage caps and dealing with the monstrous stored energy found in a suitable higher current drain capacity to hold up the high voltage you demand from your voltage multiplier.
A good rule of thumb is the impedance of the high voltage transformer, (non-shunted types only), must be must be so low that its rated output current must be (multiplication factor X the desired current output of the multiplier), i.e. a 10kv quadrupler that you want to drain 40ma out of will require the transformer to be fully capable of 160ma at 10kv. .... And.... you must figure out the huge capacitance required at 60hz in the multiplier to deliver the 40ma desired.
Power multiplication at 60hz is pretty much of a fools errand.
