I've been lurking in this forum for a good while when I was building my demo fusor, but I think I've finally finished it up to my satisfaction, delayed mainly because of money issues, and am ready to create a post about it.
I created a demo fusor that's a slightly modified version of the Makezine one.
I had a thick borosilicate glass tube sandwiched between two aluminum discs as my vacuum chamber. Vacuum pump is a Robinair one that's rated for a pressure of 15 microns. I have an electrical vacuum gauge made by CPS that is capable of reading down to 1 micron. My power supply is a 15 kV 30 mA NST connected to a Variac that I hooked up to a rectifier. I have a Fluke 1000:1 HV probe that is capable of reading up to 40 kV and an analog ammeter to measure current and voltage.
Here's some pics of the full setup:
And a selfie of me with the fusor:
Here's some nice pics I got of the plasma:
Some well-defined jets-2mA, 730 V, 80 micron
2.5ish mA, 800 V, 60 micron
I tried bumping the voltage up until I hit the 30mA max of my transformer and got a nice plasma glow:
28mA, 2170 V, 60 micron
Overall, this project definitely taught me a lot about handling vacuums and high voltage, two topics that I had practically zero background in when I started this. I'm a bit apprehensive about starting work on a full-blown fusor, mainly because I will be a college student for the next few years and I'm not sure where I can dredge up the several thousand dollars needed to make one. I really do want to though, and I'm currently scouring eBay to try to find some cheaper parts, as well as saving up some money, and I'm hopeful that sometime in the near future I'll be able to achieve fusion!
First-Time Demo Fusor Build-Plasma Club Application
- Real name: Timothy Krilov
- Mark Rowley
- Real name: Mark Rowley
Re: First-Time Demo Fusor Build-Plasma Club Application
Outstanding work Tim. Congrats on achieving this important milestone.
I am glad you got the glow mode plasma and good work, but sorry, entry into the plasma club is denied.
Read carefully the absolute specific requirements for this milestone step. We will no linger accept a glow in a jar. You must give specific data regarding the conditions observed in the image. Use your instruments!
It would have been nice if you had joined the forums a while back an shown us you project as it developed. We do not like instant claimants appearing out of the aether that is the internet.
viewtopic.php?f=54&t=13
Hey Richard,
I posted the voltage, current, and pressure ratings as I measured them for every picture of the plasma I had. What other measurements do you require?
Also I'm sorry about the out of the blue post, but I honestly just wasn't really sure about what to post-if I ever start work on an actual fusor I'll be sure to post my journey more extensively.
Mea Culpa.... I was so entranced by the pretty images that I didn't effectively see the captions...Naturally, that is why I did not read the captions. I must have been in a trace induced by the quality of the images...You are in the Plasma club. Sorry, again. Every body gets to step up to the plate and get egg on their face.
