Chris's Shennanigans
Posted: Fri May 14, 2021 7:24 pm
by ChristofferBraestrup
Turns out I can't edit title/first post of my old Images du Jour posts anymore so I'll make this general and continuous.
I've been playing around with channel electron multipliers recently, as mentioned in other, scattered threads, but finally I've gotten good performance out of them!
The trick was getting the proper preamplifiers, and a 60 MHz DSO to actually see fast output pulses.
Here's the setup: A KF40 Tee with two feedthroughs, a 2-pin one holding a crushed tungsten bulb filament (12V, 60mA), and the other HV one holding a copper foil disc with a hole to extract electrons. The filament is driven by a bench PSU, the accelerating voltage is provided by a NE RM5 ratemeter. 44 mA filament current, 6V fil. voltage, +1kV accelerating voltage.
in another tee coupled in the electron path, is a soviet VEU-6 CEM, with a grounded entrance, and an anode voltage of 2500V. the AC coupled signal out (1nF) is directly amplified by an Ortec VT120C x20 noninverting "fast" timing preamplifier. The signal is then fed to an oscilloscope terminated in 50 ohm.
The system is connected to my main high vac system by bellows hose, and the system pumped down to ~2x10^-7 Torr. As seen from the scope pics, the gain and signal shape is pretty good, peaks being roughly 40 ns wide and 500 mV high.
- cempulses.jpg (39.75 KiB) Viewed 9205 times
- cempulse.jpg (45.35 KiB) Viewed 9205 times
My plan is to modify another CEM to act as electron source (remove anode), to ionize gasses, put a drift tube inbetween and use the delta-T between the two channeltrons for TOF-MS and residual gas analysis. This idea was successfully, yet uncommercially implemented by Bendix in the late 60's
Faraday Wax - historic vacuum sealant
Posted: Sat May 22, 2021 11:13 am
I have been researching waxes for vacuum seals between glass/metal and metal/metal for a while.
Finally got my ingredients today to make a batch of "Faraday wax", as seen in J. Sci. Instrum. 13, 345, 1936 "laboratory cements and waxes"
By weight:
1 pt. Beeswax
5 pt. Colophony
1 pt. Venetian red
Melt the beeswax and dissolve the colophony into it gradually, add venetian red last and stir until homogenous. I needed around 130-140 degrees to melt it all to be fluid enough to pour, heated on a hot plate in a stainless ladle resting in a sand bath.
Poured into long thin strips for easy application.
Sealing joins: heat sealing surfaces with micro torch, apply wax on both surfaces, push together and reheat. Rotate and piston the joint slightly to make sure the wax flows.
I have yet to test this in a vacuum but it made a beautiful seal between borosilicate glass and copper, see attached.
This wax, or a very similar one has been used for particle physics as late as the 1930s, particularly present on Lawrence's 4"cyclotron:
I will be back with more info when I get it. My hope is to be able to seal BNC connectors into a vacuum flange.
Re: Chris's Shennanigans
Posted: Sat May 22, 2021 12:28 pm
by Maciek Szymanski
This iron oxide read color and copper tubing gives a beautiful vintage look. I'm very interested in the results. I'm using the wax-rosin 1:1 in many applications, but the 40ºC melting point is sometimes no-go. If the Faraday Wax can hold up to some 70-80ºC that may become my new favorite!
Posted: Sat May 22, 2021 12:43 pm
I initially thought the iron oxide was mainly for pigmentation, but the consistency of the molten wax changed substantially upon addition.
Is the 1:1 wax serviceable in high vacuum as well?
Posted: Sat May 22, 2021 12:46 pm
by Maciek Szymanski
Yes the 1:1 wax is good down to 1e-6 Torr and very easy to work. I like especially that it can be wiped clean form the disassembled parts after heating with the SMD hot air blower.
Posted: Sat May 22, 2021 2:31 pm
That's definitely an advantage. Perhaps I should make a batch of that as well.
the 1:5 wax is slightly pliable at room temperature, but fractures if snapped. It is rigid enough that pulling straight on the glass/copper joint would not let it pull out.
If the 1:1 wax allows pressures down to 10^-6 torr, one could hope that the lesser content of beeswax in the 1:5 would behave slightly better. I assume that beeswax is the more volatile of the two constituents.
I will say, Torr seal and Hysol 1C might beat this wax in mechanical strenght, outgassing and machinability, but they CERTAINLY don't smell as nice as hot beeswax/rosin does!
Posted: Sat May 22, 2021 3:48 pm
I made a small brass cover for a bored out feedthrough, to test the wax at vacuum.
With a 2L chamber on top of a EXT255H, connected to the test flange by bellows hose, the pump spins up in less than a minute, and pressure goes down to 8×10^-7 in less than 5. Power consumption the same as I usually see.
In conclusion, whatever effect the wax has on vacuum performance is below what I can measure. I am quite happy.
I never get below 5x10^-7 anyway, as I cant let it run continuously for days, and it's a non bakeable system.
An RGA would be nice to quantify the organic portion of the residual gasses in the chamber and compare.
Posted: Sat May 22, 2021 5:13 pm
Great report on the waxes! I bought and still have the $125 block of apiezon black wax I bought in the late 90's. I used it on some small discharge tubes back then and it worked great, but only used a mechanical pump then. I think the wax was rated to 10e-6 torr if memory serves. I love the red wax. If what you are doing will not heat at all or to only a miniscule degree, wax avoids a lot of expensive mechanical assembly flanges and components in test vacuum arrangements.
Posted: Wed May 26, 2021 3:27 pm
Thank you for the interest!
Bringing back a bit of experimental physics history feels nice.
I have just mounted a non-vacuum BNC of "decent" quality in a KF25 flange, only sealed with the Faraday wax. The teflon insulator gap is also sealed.
It seals as well as previous tests would indicate, thus providing a very cheap route to hermetic feedthroughs!
10^-6 torr in less than 2 mins from turbo spinup!
I made the seal, tightened the bolt down, then reheated the seal as the bolt undoubtedly cracked the seal.
I put a simple faraday cup on the end just to pretend I might use it for something someday...
Posted: Wed May 26, 2021 7:46 pm
I love the funny bit with the Faraday cup handle... Nice work. carry on. A bit of history and humor are always held in high regard here.
Posted: Thu Oct 28, 2021 3:56 pm
A glorious trip to my uni garbage container!
- A NIM-bin (with +-6V, no110VAC)
- 2 Spec. amp's
- Canberra 2006 prop. counter preamp
- Outokumpu 0490 Be-window proportional counter
- A load of SHV, MHV, BNC cables -including crossover between the two former
- A homebrew Mössbauer drive with PSU
- A toolbox full of KF O-rings, clamps, and miscellaneous parts. (not shown)
- An X-ray diffraction crystal with mount, likely LiF (not shown)
- Some 1m long KF25 stainless pipes
What a rush. The bin was bolted to a 42U rack, and I didn't dare leave it alone (lots of dumpster divers who are just after selling the copper and steel).
I had to phone a friend at my lab, asking him to come down with some tools fast, under promise of a bagel. Good investment.
Either way I made the trip home with the bin in the train today. Very unhandy way of transporting gear.
This has all been part of a Mössbauer spectrometer - one of the great mystery techniques inbetween nuclear physics and chemistry which i still don't quite understand. Another is PAC spectroscopy.
There were also a complete Oxford superconducting magnet with He cryostat and an X-ray diffraction goinometer but I left those, since I couldn't find a forklift operator who would take bagels as payment.
Posted: Thu Oct 28, 2021 6:32 pm
A very nice bunch o' loot, and the price was right.
Posted: Fri Oct 29, 2021 2:42 pm
But wait! There is more! Deep down in a box of spare parts for the cryostat i found a little packet of a metal foil and a little bag of metal wire.
The metal is not labeled but it is extremely soft and very dense, and too shiny to be lead.
I believe it's probably indium, as it is commonly used in vacuum and cryogenic (and especially the combo) system.
If anyone knows a good test for indium id be happy to hear it!
Posted: Fri Oct 29, 2021 5:36 pm
Pure indium is like a metallic crayon. You can draw conductive lines on paper and get the metal all over your hands. It is not dangerous.
