Finn Hammer, fusor update.
Re: Finn Hammer, fusor update.
Great work Finn. I am glad you already have some of John's fine work. I wish you could meet him in person. He is a calm, very retiring and reticent person who is incredibly easy to like. Perhaps if you ever make what few HEAS October events are left in me, you can meet John.
Your effort is one that mimes my own in its temporal journey, which I find the best way to get into fusion. (Slow and easy - Read, do, absorb, correct the do, read some more, do some more, repeat) Of course, you have the best of us to soak up a lot of hard won knowledge. This can shorten the journey, but still, you move at the right pace, taking advantage every wrong thing made right over the years here. It is the right way to do it.
I wish others would enter this way.
Finn Hammer
Real name: Finn Hammer
Post by Finn Hammer »
I had first light the other day.
At this point, I knew that the solutions I would come up with would probably have to be altered along the way, possibly in short order, so I allowed myself to delve into the fine art of jerry rigging, the ballast resistor being the first item to receive my left hand attention:
You may be able to see the 3x16 matrix of VR68 resistors, they did not last long......
Next attempt was a 5X10 matrix, this time potted with heat conducting potting in a FR6 tube, it lasted for one hour of testing.
The long thin tube is the voltage divider 1:1000, it seems to be a good one.
One success to report is the voltage control on the feedthrough, it is good.
I had made a squirrel cage grid with 9 pins in it, and this was for the sole reason that I wanted a spanking cool 9star picture as my future avatar, well that turned out to be a bad choise, at least since the axis pointed right at the viewport. I had some bad expectations beforehand, and for that reason I had put sacrifical glass in front of the viewport, this should prove beneficial.
I got my nine star, but in the wrong place, as a blue reflection on the viewport, but what was worse, the front hole in the grid shou out a death ray directly on the glass, which got damaged.
You can see how the glass (quartz) got chips blown out of the surface where the death ray hit.
Ok, back to the lathe and make a new grid:
This one showed out to perform better:
and soon It got all red hot.
If I could only figure out how others manage to catch theit fusor internals without all the haze, perhaps it is a photoshop thing
Cheers, Finn hammer
Jim Kovalchick
Post by Jim Kovalchick »
Finn,
Great looking plasma pics!
Regarding haze, fusors tend to look hazy until the chamber conditions through heating. I'm betting yours will look clearer soon.
Jim K
Real name: Mark Rowley
Post by Mark Rowley »
Finn, Ive always had similar problems taking distance shots of the fusor and BoT. Seems that the autofocus latches onto the exterior hardware rather than the slightly more distant plasma within the chamber. My remedy was to place the camera right up against the viewport (using a makeshift insulator) allowing for focus on the grid or BoT target. Sometimes taking a video from the same distance will work better. Then it’s just a matter of taking a screenshot from the video.
Regarding the squirrel cage (SQ) I always wondered how folks kept the axis beam from blasting a divot out of the viewport. The latest videos of Dougs fusor display some great imagery of the SQ in action but there’s no evidence of any beam hitting the viewport. Quite possible there’s a sacrificial lens there but knowing the high power levels he ran I can’t imagine it lasting long. I also can’t imagine him cracking open his chamber all the time to replace it either. It’ll be interesting to find out exactly what he did.
The diameter of your new copper electrode appears to take up a bit of real estate within the chamber. I’m curious if you’ve noticed any problematic interaction with the chamber wall. One of the BoT targets I used which incorporated fixed magnet electron suppression was of similar size. Just big enough to cause a Paschens Law issue with the nearby chamber wall. I know BoT dynamics differ greatly from the fusor but I’ve had similar issues a couple years ago when experimenting with larger fusor grids.
Finn Hammer
Mark, Jim
Regarding the photos, I am stunned. It is not an autofocus thing, I set the focus manually, by shining a flashlight on the grid, so I can see the focus well, camera on a tripod, lens is the famous 200mm Nikon Micro, sharpest lens available. But still there is that blue ionizing thing. I saw it in the big triodes on my single ended tube amplifier too, but not to this extent. I am considering to afd a grounded mesh in front of the sacrifical glass in the viewport.
Regarding the grid diameter, no problems as I see it, no flashovers to ground or anything like that. The first couple of minutes, there was a sort of sprinkling on the surface, as if small specks of dust provoked breakout, but were extinguished in the proces, that is all.
But mind you, I have no idea whatsoever, which diameter is the right one, or more suitable, I use the rule of TLAR ( That Looks About Right) and with my limited experience, that does not say much.
But I did go to the junkyard to get short pieces of stainless tubing in 15 - 22 mm range, and I am quick on the lathe, so many grids will be tested, as soon as I get a suitable ballast resistor. Those power mox resistors look tempting, to end all experimenting on that part.
Cheers, Finn Hammer
Real name: Frank Sanns
Post by Frank Sanns »
Great work on your setup Finn. Top rate.
As for the photos, it is not the camera or radiation. It is a dirty chamber.
Any fusor that is open to the air will have a fog within the chamber. It is outgassing.
If deuterium is added soon after the pump down, the color will look a bit ruddy. This color will clear up rather quickly but the haze can remain for the better part of an hour of operation or even for hours if the fusor was just assembled. Run longer and glow cleaning will clear things up and you will get tack sharp pictures.
The camera is more sensitive than the eye to the haze because of the longer exposure. You may no longer see it but with more light making it into the camera image, it will show up. A good indicator of how clean your chamber is. A necessity before you start getting good neutron numbers.
Jim Kovalchick
In addition to the chamber conditioning that Frank and I spoke of, the blue haze could also be your viewport glass fluorescing. Especially with that tube grid, as you noticed, there is a secondary electron beam hitting your glass. Borosilicate fluoresces blue.
All good points. Jim, you me minded me of the UV fluorescence on my ion source. Finn, could this be what you’re seeing?
Great work Finn. I like the photos. Once you get a stable system with a good ballast, you can start smoothing out your operational experience that will become a natural function of your hands at the controls. once you are in the groove, you will become extremely sensitive to any sudden changes in operational characteristics. Smooth stability in startup and running is the goal. Early on, a fusor can be all over the place. Every time you open the system or change a grid, it is a whole new ball game, starting from scratch and having to get use to new characteristics.
Finn Hammer
Frank,
Thanks, good news if a dirty chamber is the reason, dince there is s remedy for that.
I had gotten sloppy with the chamber cleanliness, time to take it apart for a vigorous rubdown.
Mark,
UV flourescence sounds about right.
Jim,
The sacrifical glass is quartz, I forget whar the Lesker viewport has.
Cheers, Finn Hammer
Finn Hammer
The ballast resistor.
There are some chinese wirewounds that claim to stay within spec. both voltage- and powerwise, but given the urgency (which is, of course, more imaginary than real) and a bit of scepticism, combined with previous excellent experience with Ohmite's products, led me to the conclusion that there is really only one possible candidate for a ballast resistor, as aquired across the counter, and it is one out of the Power-mox series, from Ohmite.
Mouser has them, and the item shipped free from the US to Denmark, but then it is not exactly cheap either.
I have no doubt that it is worth every penny, now that it has been in my hands for a couple of days. This is what quality looks like:
Quality!
Quality!
Now, it does not come in the funky non-inductive style that "they" parade on their product page, because it is what we all would want if it was available,
Funky but non-stock!
but apart from that, it is everything desirable, ceramic former, thick film resistive spiral and the coolest clear lacquer finish. And the 11 turns work out to 0.3µH, so what.....
Only complaint is the radial attachment lugs, I don't like them. Lots of sharp pointy edges, lots of places for corona to form. Corona, the dreaded mother of all arc discharges, the culprit of every surface track. Something had to be done, and what.. isn't that why I made that radius attachment to my lathe? so that I could whip up a nice couple of toroids in short order?
After another day in the workshop, this is what I had available:
The toroids are mounted to the resistors collet style, not unlike some potentiometer buttons attach to the shaft (the good ones that don't mar the spindle with set screw marks) and some phenolic and FR4 trimmings to suspend the assembly.
The finished article looks like this:
The rated power dissipation as I^2 x R losses is 50W, so it can support a continious current of 31mA to flow
The ballast resistor only sees the full voltage across the element for a brief flash in time, just when the arc strikes, otherwise the voltage drop is a maximum of 5000 x 0.031 = 158V,
(Edit: woops, should have read 50000, not 5000, for 1580V)
but the whole structure will be floating at whatever voltage I dare to throw at it, and since I don't want to use oil, and neither want it to arc to surrounding grounded parts, that is the reason for this litle exersize in field control.
The fact that it is also pleasing to the aestetic senses is only an added bonus.(Us seasoned tesla coil builders have an incurable, weak spot for toroids).
Cheers, Finn Hammer
Even in a dangerous pulse of current the voltage across the resistor will not reach a level to arc running end to end on the resistor, the voltage is near zip. At a run current of 20ma you are looking at 1kv across the resistor. (50,000 X.02 = 1000volts) The resistor would internally arc band to band, (assuming zero supply impedance), long before it would arc toroid to toroid in a pulse condition.
Unfortunately, there is the real impedance of the supply thrown in, buckling the output voltage and the plasma arc impedance within the arcing fusor. This limits arcing possibility within in the ballast resistor.
Still, you have closed all possible doors with this overkill. Slick, polished insulation on flat surfaces accumulate dust to create paths not expected. Those toroids are awful close to that surface.
Finn Hammer
You see it all.
The dust is one aspect that I had not given any consideration, and although the assembly is being mounted upside down, with the resistor hanging, there is no telling what electrostatic forces can do to throw dust upwards.
I may have to redesign the FR4 standoffs for more clearance.
Cheers, Finn hammer
Real name: Dennis Brown
Post by Dennis P Brown »
I submerged my ballast resistor under oil; fully synthetic auto oil since that is actually superior to many transformer oils. It not only electrically insulates it but dissipates heat significantly better than air.
When checking out my x-ray transformer back in 2004 before installing it in the fusor IV rack system, I put my 63kohm, 100W ballast resistor in the tank with new HV silly cone diodes all in the oil. There it has resided for the last 17 years along with the diodes. Once pulling out the vacuum rectifiers and filament xfrmr back then, there was a lot of room for the new diodes and ballast.
Finn Hammer
Arriving back from Copenhagen, from my 9 day masonry assignment, one of the first things to do, was to bring the cube back to life.
I had left it with all valves closed, and pumped it down below 1E-5, which is the lowest reading on my current transducer, a 901P.
Immediately, I started to introduce deuterium, and settled for 22microns, then cranked up the voltage.
Getting stable operation is a breze, and soon it was running at 20 microns, 29kV and 12mA to produce, after 4 min. run, 700CPM on the Ludlum model 3 with the 44-9 frisker probe.
I did 3 more runs, finishing with a 10 minute run which was particularly good, because I found out how to bring the beast up to power slowly, which surprisingly made it possible to operate at 24 microns, 29kV and exeeding 15mA with the grid getting only a dull red. This produced in excess of 1000CPM.
The Canberra dosemeter started to report 500 microroentgen, so I stopped the operation of the fusor for this part, untill leadshielding is in place, and the Ludlum Model nine has arrived. At that time, I will swap the 30kV multiplier to a 60kV unit, and try not to break the feedthrough.
Edit. Changed CPS to CPM, these being counts from the silver foil made off a 1/4 piece of a silver dollar, hammered out.
Cheers, Finn hammer
Finn, Great system! I retain a leaky fusor and can't restart as rapidly as many with a very tight system. I am sure it is due to my HV feed through. I am envious of those who can instantly restart a fusor to max function after a week or more of being left fallow, but sealed off. You have done great work and it shows. I need a minimum of three consecutive days of "conditioning" to obtain top level function. After that the next day I can blast right up in mere minutes as reported a few weeks back. A single week of inactivity will force at least two days to recondition. A month or more will need three days and 3 months, about 4 days. Just be glad you have a system that is well sealed.
As you know I created a nice little Arduino box slung under my fusor and imbedded a GM tube with silver or Rhodium wrapped around the tube in my 3He neutron detector moderator. I had the Arduino count for 10 seconds and record the count and sent the total to Arduino EEPROM memory. Then it counted again for 10 seconds and stored in the next EEPROM cell and so on. (This counting is initiated the instant the fusor is shut down) Then using the serial monitor in the Arduino IDE, I transferred, (dumped) the stored EEPROM data as a simple text file to a laptop via the USB port on the Arduino. I next blew the comma delimited text file into Excel to create a nice graph of the decay curve. Worked out great. I later changed the count period to 5 seconds. (only had to change one line of code). I will note that due to the variability of short 5 second counts in my rather noisy lab background, the curves look a lot better if my fusor is cranking out 7.5e5 or more n/s TIER during the activation period.
There are so many cool things one can do like this. Naturally, you can no longer swap, with any ease, activation materials by doing the above, but it does allow for two detection methods in one moderator i.e., electronics and activation which can be seen and proven in a demonstration rather quickly. One can still have a "neutron oven" near the fusor for rapid swapping of different elements for activation if desired.
I just found it interesting rather than to demo my fusor with a screaming electronics neutron counter, while doing fusion, to show that the instant the reactor was cut-off, (dead), have a new count now issuing from a radioactive neutron activated element which the neutrons created and to see the decay plot match the decay curve predicted. Many folks do not demo their reactors on a regular basis. I spend many moments demonstrating my fusor for interested persons and groups. I found activation a great way to prove to skeptics that I had done fusion. I often find that a person or people I demo the system to will tell others who are incredulous and unbelieving. This will usually setup yet another demo, in future.
Finn Hammer
With the 60kV greinacher in place, I did a 4 minute run at 40kV today, 25 micron and averaging 15mA, to do activation of 90% silver/10% copper, from my crummy piece of hammered out silver dollar.
This produced 2400 CPM on the 44-9 frisker probe. This is a new record for me.
It is interesting that the tube cathode seems to heat up to a lesser degree at 40kV than at 30Kv, same current, I would have guessed the opposite, not that I am complaining.....
A new instrument came in the other day:
With this in hand, I could measure the radiation from the running fusor, and at 30kV, 20mA it generates 0.4mRoentgen/hour at 2 feet distance from the front face of the fusor.
This was without lead shielding, however the viewport has a quarter inch of lead glass. this glass is the equivalent of 1.6mm lead, which I was able to confirm by exchanging it with a piece of lead that thickness.
Running the fusor without the leaded glass, the radiation shot up to 3.6mRoentgen/hour.
I am waiting for this book to arrive:
Radiation Detection and Measurement
Glenn F. Knoll
Simply because it is not at all obvious how the different units relate to each other. I do know there is a factor of 100 between roentgen/hour and sieverts/hour, so that 0.4 mR/Hour translates to 4µS/Hour, and using this chart:
I deduce that 10 hours of fusion will put me square with a traveller by plane from NY to LA, which should not pose any concerns. For now, at least.
How to get from Sieverts to REM is another ballgame, but hopefully the mentioned book will fill me in on that aspect.
Anyway, nice to run and tweak the fusor.
If I should say something central about the cube fusor/cylindrical Kathode configuration it is this:
The cylindrical Kathode will quite possibly save the newcomer from one inevitable setback of the traditional grid: The meltdown.
The possibility of including water cooling of the body and endcaps at design time means that the fusor can run for hours on end without overheating. I have done 20minutes at full bore, with only a 15 degC raise of temperature.
But to get the best of these two hardware features, the access to -and ability to operate- a lathe, is mandatory.
Cheers, Finn Hammer
Post by Rich Feldman »
Belated applause for the ballast resistor with anti-corona toroids on the ends. They are solid aluminum, right?
A work of art and science!
I was reminded of it last weekend in San Jose, California (at 4th and Taylor).
Perhaps for safety around the exposed neon, which had been left "on" that summer afternoon.
Finn Hammer
Rich,
Noticing things like that is a sure sign of highvoltageitis. I suspect many of us have it. Thanks to god, we don't have to suffer from it.
Below is the present lash up, I am starting to see the wisdom in having the high voltage feedline coming down from above.
Cheers, Finn Hammer
Knoll's book is a classic for millions looking to learn about radiation and detection methodology. You will use it as a reference. Europe is the home of metric and S.I. units. I tend to use the older units and the CGS system of metric when talking science. The only S.I. unit that is spot on for me is the Becquerel as the unit is small and handy. The Tesla is one of the most insane of all S.I. units. 6 Gauss is .0006 Tesla...(stupid). Seiverts and Grays have no place in my lingo. It's what you grow up with, I guess. I was taught poundals and Rels in college, but never used them in the real world. CGS metric is a true laboratory desktop frame system, thus I hang with it. (ergs and dynes). I went full metric in CGS and am still choosing English in Machine work, though on some projects I go metric just because I have good metric dial calipers on hand.
The Rutherford unit and the REP had very short half-lives of any unit for radiation measurement. You have to be reading texts from the 1950's to find those. Too, many instruments that still work well and even being currently manufactured in the U.S. are still reading Roentgens and CPM to have those units just disappear from "rad speak".
Scientific papers are only accepted in S.I. units. Have no fear, the S.I. units are just here for the time being until someone pushes for all new units and "proper speak" in the scientific community among the properly "anointed". We old boys will have to die out before some of the old units die in the speech related to radiation here in the U.S.
How many radioactivity standards still use curies instead of becquerels?
Agree with Richard that the smaller unit is more handy and intuitive, though when applied to a freshly retired nuclear reactor core, it calls for rarely used large-number prefixes. I like the smallness of magnetic flux unit maxwell (gauss x cm^2) instead of weber (tesla x m^2), because it can be called "one line of force" in training classes.
Torr is an interesting unit 'cause it's no longer based on mercury (with adopted values for density at some temperature and gravitational acceleration at some place). It is exactly 1/760 of 101,325 pascals.
A couple of generations have learned to say gigahertz instead of kilomegacycle, and picofarad instead of micromicrofarad.
Those units and multiplier prefixes predate SI.
I hope my lifetime sees universal return of mega and giga to mean 1,000,000 and 1,000,000,000.
As they have always meant for resistance, frequency, digital data rates,
and data storage without an address bus.
It's ambiguous and unnecessary to call 1,073,741,824 bytes a gigabyte; that amount is a gibibyte (GiB).
Now back to Finn's fine fusor...
Finn Hammer
@Richard and Rich
I appreciate your musings, personally I used to think that the Tesla was right on the spot, but then I was into building field coil loudspeaker magnets, where the saturation of the iron pole pieces happen at 2.1T. In the case of the permendure alloy, 50% each of cobalt and iron, 2.4T.
Anyway, to speak about the steampunk dragon, i took the viewport off last night, to align the cathode with the horizon, only to reexperience, how blue the hue of water vapour is.
After the night pumpdown, this morning things started to look a lot better, and I did another run, timed for 6 minutes.
Starting out at 44kV, ending at 47kV,
24microns more or less stable throughout the run
17mA trending towards 20mA at the end
0.8 Cubic centimeters of deuterium per minute
This produced 3.4Kcpm on the friskerprobe
Same old silver dollar alloy.
There is a mable leaf canadian in the mail, and it will get hammered to meet the diametre of the 44-9 probe, and thin of course, then we will see.....
It amazes me is, that although the cathode gets close to the melting point at 20mA/30kV, at 45kV it just trots along at 20mA, at nothing more than a brownish red. 45kV is the present sweet spot. I could leave it uncorrected for the last 3 minutes of the run.
I met with a physical limit today, during the initial burn in.
At one point, the pressure dropped to a level where the plasma extinguished, which caused the voltage to shoot up high.
A later test with a rolling camera, showed that at pretty exactly 60kV, the field controll on the 30kV feedthrough lost it.
https://youtu.be/xTBTRLbSff8
Cheers, Finn Hammer
Finn, welcome to the club! That is the exact thing that happened 6 times to me last year and the 7th time blew up my Turbo controller. Air will take only so much even with field control! At least it was external and did not track you insulator. Did it kill anything in your setup? I hope not. Now you know your "rope limit" in voltage within your current setup.
Finn, oil is your friend! Trust me!
Too many folks here have thrown stones by claiming it’s “messy” or hard to deal with, thus establishing an unfair bad rap. Just like all disciplines in our hobby, take the extra precautions and you’ll have little to no issue.
All that aside, the aesthetics of electrostatic field control are an unparalleled art form.
Return to “Images du Jour”
