Finn Hammer, fusor update.
- Finn Hammer
- Real name: Finn Hammer
Re: Finn Hammer, fusor update.
Liam,
Interesting thermal image, thank you very much.
I have been wondering how the thermal "reach" of a colder stem would affect the temperature at the far side of the kathode, but your simulation shows that very well.
However, the old kathode melted on the side facing the stem, which had no more cooling than a 2.5mm stainless stalk could provide, (neglectible):
From this I gather, that the old stem was heated to a point where it contributed to the kathode temperature, to form a hot spot at the stem/cathodetube junction. By cooling the stem, and reducing its cross section, I hope to reach a point, where the hottest area of the kathode is facing me, not the stalk. Both the stalk and the cathode is Molybdenum, with a thermal conductivity coefficient that is superiour to that of stainless steel.
Thermal conductivity coefficient : https://www.sciencedirect.com/topics/en ... oefficient
Copper: 386
Molybdenum: 143
Stainless: 25
The layout of the viewport is sub-optimal, because I view the kathode along the stalk axis, whereas if I viewed it perpendicular to that axis, I would have a view to the stalk. This was due to the initial desire to run a squirrel cage kathode, which did not doo well, and I am suffering from this decision now.
Cheers, Finn Hammer
Copper: 386
Molybdenum: 143
Stainless: 25
Cheers, Finn Hammer
- Real name: Peter Schmelcher
Keep in mind a Heat Pipe for cooling, lots of energy in water phase change. A Heat Pipe transfers heat far far better than a solid copper rod.
-Peter
-Peter
- Finn Hammer
Peter,
I will read up on heat pipes, I have only a vague idea about how they work.
In this first cooling attempt, I rely on air to transport the heat away, and if the compressed air carries moisture to any significant degree, the plastic pipes wil turn into conductors. Lots to ponder...
Cheers, Finn Hammer
Cheers, Finn Hammer
- Liam David
- Real name: Liam David
I'm not convinced that a heat pipe, or even an infinitely thermally conductive center conductor for that matter, would reduce the temperature of the cathode much. The heat transfer bottleneck is the cathode itself, as well as the rod that connects it to the copper, per the high gradient there in the image. In the simulation I've set the inside of the copper tube as a 20C boundary condition, which represents perfect, infinite cooling capacity. With forced air it will be much worse. Also, I simulated an aluminum cathode (239 W/mK vs 143 W/mK for molybdenum). All that said, I'm sure the cooling will prevent the copper and rest of the feedthrough from melting even when the cathode is red-hot.
- Finn Hammer
Liam,
That sounds good, since I am shooting at white hot .
Cheers, Finn Hammer
Cheers, Finn Hammer
If the grid was a double walled cylindrical cavity that was a continuation of the heat pipe tube interior, then steam or water vapor will keep the entire grid under 100C. The heat pipe cooler end needs heatsink fins with moving air so the water condenses and runs back to the grid, no free lunch. CPU heat pipe cooling uses a lower than atmosphere internal pressure with water boiling at about 40C. Alcohol, ketone, etc. can also used in heat pipes plus wicks so the liquid returns without gravity assist.
-Peter
-Peter
- Finn Hammer
Double walled cylindrical cavity, beleive me, I have been there, and good luck fabricating that one. Anyway, my goal is to prevent the kathode from melting, not lower the temperature to below 100 degC, I want it hot.
Fabricating a heat pipe means controll over the internal pressure before sealing it, and knowing how much working liquid to trap in it. Then there is the wick...
Not going to happen soon.
Then there is the radiator at the high potential.
Nope, no heat pipe just yet.
But thanks for the input , it widened my awareness of things.
Cheers, Finn Hammer
Cheers, Finn Hammer
- Finn Hammer
All,
While the jury still is out, with regard to the success of my new Kathode assembly, testing it has produced the following decay graph, using Silver.
I have wondered why Richard and Bob both tout 5 second count intervals, and I now understand why:
While I erroneously figured that closer spacing of the samples would produce a smoother graph, actually this is not so. By taking the samples further apart, the values will be averaged and the curve will become smoother. Slightly coarser in the horizontal direction, but much less jaggedy in the vertical aspect. This will be incorporated in the future graphs,
For now, this is what I have.
In an attempt to validate the graph, or characterize it, or to find a way to recognize it as a Silver decay graph, I have drawn lines which are supposed to represent the expected decay of the 2 isotopes involved:
The red line represents Ag109, which activates to Ag110 at 89 Barns and should be dead after 5 times 24 sec = 120sec.
The green line represents Ag107, transformed into Ag108 at 35 Barns. This should lie dead after 5 x 2.42min = 800 sec.
The starting point of the green line is calculated like this: The initial count is 260 which I equal to the combined amount of capture Barns, which is 89 + 35 = 124.
The starting point of the green line should then be ( 260/124)*35 = 73
There are probably a lot of factors involved which makes this method invalid, I should hope so, because the decay curve is below the prediction all the way.
Input is invited.
Edit:
Here is a new decay from 8 minutes run, 20kCPM done by 27microns, 18 mA, 41kV and sampled at 5 seconds intervals. Much better.
This is on par with the best previous run, so still making neutrons allright.
Cheers, Finn Hammer
Input is invited.
Edit:
Cheers, Finn Hammer
The second graph is the one to go with. Plenty of activation here. You do not have the background that I have to deal with and it is much smoother than my 5 sec samplings.
- Jim Kovalchick
Finn,
Just a thought on drawing decay curves where there is multiple isotopes that hand off to each other over time. When trying to draw lines over the curves to match the actual decay as you did in one of your posts, it is best to plot the y scale in log because decay is an exponential function. If you plot your data that way, you will see straight lines that match the dominant decay constants.
Jim K
Jim K
- Finn Hammer
After the total meltdown, I decided to bring the fusor up to the standard that it should have been at to start with.
This involved the manufacture of a multitude of special cables for the turbo, the 901P’s, the baratron, the flowcontroller and several more.
I also built a remote control console, and this was getting obviously urgent, since I had experienced a couple of situations where I had that slight feeling of sunburn in my face after a fusor run. Lead is good, distance is better, and I can now operate the fusor from 18 feet of distance.
Finally I modified the new feedthrough that I showed off recently, but which developed plasma between the stem and feedthrough flange already at 40kV. This plasma formation occoured at below 15micron only, forcing me to initiate plasma at higher pressures, and work my way into lower pressure, and the associated higher voltage, but still limited to 15micron/35kV.
The solution was to manufacture a longer 6mm molybdenum stem for the grid, and shorten the 12mm cooling stem accordingly.
I will go into this in more detail in a following post.
The resistive divider I use is made from 30 pcs. 47M VR68 resistors in series, and the bottom is 3 pcs. 47k 2W resistors. Externally is another 22k resistor which compensates for the 1M parallel readout. The chain potted in the clear epoxy you use to make floors and river tables of, I use the slow curing version, good for up to several inches of thickness layers.
This has also proved to be a good potting compound for the voltage multiplier. My previous multipliers had 1K resistors in series with the diodes, but the dissipation in these resistors was approaching 3W each, as verified by LTSpice, and even the best heat conducting potting could not transport that heat to the surface. This led to destruction of the resistors, followed by arching in the void along the body of the resistors, and eventually big bulges showing up on the surface of the potting compound. I had to break the multiplier apart to find out the full story, and obviously this internal arching was a cause of a bad, flickering instability in the plasma.
In an attempt to remedy the problem, and also get instant insight to the individual parts of the stack, I tried to omit the series resistors, and use the transparent floor pouring epoxy, and this has held up so far, I consider it a success.
The foreline is monitored by a 901P, which is really the swiss army knife of vacuum technology. The internal set point relays, the RS232 communicating protocol, and the ability to emulate analogue output of 23 different transducers puts it in a class of its own, there are so many great things inside it, but then… it is made in Denmark!
In this setup, It is configured to emulate a 100 Torr Baratron, and one of the set point relays is set to control the roughing pump, via a solid state relay, so that it is running from atmosphere and down to 4 torr, then shut off from 4 torr and up to 10 torr, at which point it turns on again.
The manual is a bit ambiguous in defining the right commands for the set point relays, so here is what I feed it, to make it perform the desired functions:
Setpoints:
@253sp2!4.00E+0;FF
@253sd2!below;FF
@253sh2!1.00E+1;FF
@253en2!abs;FF
100 torr Baratron:
@253AO1!313;FF
Cooling system:
New manifold, components no longer on the floor. Run simultaneously with the power supply!
To get the many wires from the transducers, pumps etc. routed up to the remote, ..... I admit it, I made a mess here, but every single cable is documented in a spreadsheet, and so are the terminals, so I know where the wires come from, where they are going, and what they do. But pretty it is not.
Here is a view of the present iteration of the fusor
And another view from behind:
However, the chamber displays the same clean atmosphere as before:
And it payed off in silver dollars. after 3 runs at 12minutes each, the last one topping out at 60kV, 30mA activated silver to 45kCPM, twice as much as before, as seen in this video.
45kCPM run
Cheers, Finn Hammer
Setpoints:
@253sp2!4.00E+0;FF
@253sd2!below;FF
@253sh2!1.00E+1;FF
@253en2!abs;FF
100 torr Baratron:
@253AO1!313;FF
Cooling system:
45kCPM run
Cheers, Finn Hammer
MOST EXCELLENT!!!!!
- Real name: Matt Gibson
I was wondering what you’ve been up to…Quite a lot!
If the Germans' decide to build the next generation stellarator then you Finn should be the primary Engineer*! Impressive build to say the least. Nice you got the improved activation after all that work, money, and effort. Congratulations on a job so very well done; including the documentation you published here.
*Though even you might not have considered using large helium balloons to hold up the complex power feed lines for the stellarator's upper body - serious, if one wants to look at a beautiful yet silly engineering solution to a construction problem, that solution is both the most clever and fun I've every seen!
Really fantastic! Remote operation is the way to go, be it at a range of 2 meters or 20 meters. To do this, however, is not for the neophyte DIY guy. Knowledge of system assembly, electronics to a deeper internal level, some cash outlay and the drive to do it are needed. As always, you build it....You know it! Every wire and item in the completed system was machined, assembled and placed there by your own hand. Any centralized computer or micro processor controlled element has been fully understood, programmed and debugged by you. Again, fantastic!
The term "you" in the above paragraph refers not only to Finn but to anyone looking to do what Finn has done. We who have really "been here" over time, have seen Finn arrive and have followed his relentless effort. He has been slow and confident after each step over the time he has been here. He has shared every time he has done something relevant which is what the term "open source" means in our credo.
We sadly saw Finn depart for a period with his promise of "I shall return".... Return he did! None were happier than I to see him come back. Hitting the fusion ground running, he has become somewhat of an icon in sharing his work. His work is not only inspiring, but of a high order that few here can be capable of in ability or in finances necessary to dive into the effort to this level which certainly exceeds any preceding "over kill" effort on fusion hardware perfection.
To set a goal equal to Finn's is certainly a bridge too far for 99.5% of any who might grace these forums. However, Finn's work shows what the right combination of the "right stuff" working behind a verve and drive to "do" can accomplish.
I must say that for my simple assessment, we are at a point in this effort where the power of what is seen today, in these forums, far outshines any previous effort seen here. We have more folks operating at a level in the amateur fusion effort than has ever been seen. Yes, I will also admit that those old glory and often gory days of clawing into rapid understanding and early vibrance coupled with the "doing" by many of we "old boys" are gone, but look what we dragged in here to supersede us!! Wow!
- Finn Hammer
Matt, Dennis, John and Richard
Thank you for your kind words.
I must give it to you, Richard, your enthusiasm knows no bounds, and even though it is nice to receive praise like that, I must admit, I don't quite feel comfortable being put so close to the top of the heap.
Here I am, no electronic detection, no gammaspectroskopy, no deep insight in everything nuclear.
There are so many others here:
Mark started to build those homemade chambers in the 2020 fusor, and, and, and
Jon perfected it in the cube fusor thread
Liam layed down the basics of the feedthrough
Maciek defined the perfect valving and buffer tank layout for the pumping station
Andrew showed so many advanced solutions, and recommended the lead glass viewport
You, Richard, helping with everything nuclear and ....-everything!.
I must share the praise with you guys, and many more that I don't recall right off the bat, but you know who you are.
I was raised, and live in a country where nuclear power has been frowned upon, weapons even more so. We don't have hot rocks laying around and no Oak Ridge operations to buy calibration sources from. The nuclear aspect of this hobby is going to be steep uphill from this position, but challenge accepted.
I knew nothing about electronics untill I joined the Tesla coiling Community at the Pupman list 20 years ago, the main list moderator, Terry Fritz, was a mentor to me, and from him I learned that sharing your work is the frosting of the cake.
I learned about power electronics from great minds like Steve Connor and Richie Burnett. And to a large degree from Ray Ridley, but he does not know that.
All this leaves me with the high voltage supply, which at present has topped out at 1.8kW.
That one I take full credit for.
Yours humbly, Finn Hammer
Finn, If you read my PDF in the Admin section, about Observe, learn, do and teach, we all know among us who the real solid folks are. I did not name the so many others that you mentioned who certainly share the accolades I heaped upon you. Modesty prohibits many, yet, it is good to point out specific accomplishments when so obviously well presented in these forums. I am really covering all of those here who are real contributors when I heap praise of any specific individual. Those here and now, know who are among the best and most active currently. The old boys have seen many fabulous contributors of the past come and go. All newbies will learn who are currently the leaders and teachers. A tiny fraction of these newbies will certainly rise to the top in future. Teaching is not all in lecture but in showing how things are done. This inspires someone, which is the first step .... Observe! Then if a newbie has a fraction of the "right stuff" Learn is the next step and this involves self directed learning. If this occurs, the newbie is on his way.
I did not want to say anything about European countries in a negative light. We in the U.S., in spite of freedoms being infringed upon almost daily, still live in a country where there are a vast number of opportunities that our fellow members of the world community are denied for one reason or another. This is why when others, outside of the U.S., do such a commanding effort against many odds, as you have, I must arise with praise for the effort displayed. Some people here have no concept of the limitations placed upon others outside of the U.S. when seeking to do advanced amateur science experimentation. You folks run into so many roadblocks that we never see here.
- Finn Hammer
all,
Fine instrumentation should be put to use, and following are a series of comparative measurements, where the voltage is kept as accurate as possible, while cranking up the current, by increasing the pressure.
The curves start to fall off around 5-10mA and beyond that, the reign of diminishing returns starts to kick in, sort of......
However, it also brings about some great promises to when I can exeed the 75kV, which seems to be the limit of operation with the new feedthrough.
At 75-80kV, arching starts to occur, and that is the topic of another post in preparation.
More to come.
Cheers, Finn hammer
More to come.
Cheers, Finn hammer
Hi Finn,
I was hoping you would post some results with the new Ludlum!
Are your CPM values the straight reads from the Ludlum or have they undergone some math?
Any chance you could do a run at 40kV for me? That’s my max and I’m trying to compare what I’m getting to someone that has a working fusor
-Matt
-Matt
- Finn Hammer
Matt,
Sure, I will do that tomorrow.
The numbers you see here are counts per second, and that is the millirem/hour numbers from the 2363 multiplied by 350.
Read the manual and Andrews postings again and again.
I recommend you take ownership of the numbers for examble use this method, which is how I do it:
First during a run, start the software, and initiate the 1/2second counting.
End the run, and save the data collected.
Open the data file in a text app.
Copy all the data, and paste it into a spreadsheet, using the import tool, and use comma separted format.
Delete all columns, except the neutron one
Create a column to the left of the neutron one, with cell entries starting with one, and increasing by one half, downwards.
Now create a column to the right of the neutron one, which contains "=b3×350" (provided your first neutron entry is in b3) and auto copy that one down.
Now you can highlight 1st and 3rd column and insert a diagram, xy type, and presto, you have a graph of cpm vs time.
You can also divide by 5670 and get the neutron cps, if the hammer is 8 cm from the center of the fusor.
Hope this helps.
Cheers, Finn Hammer
Hope this helps.
Cheers, Finn Hammer
What are some of your mR/hr values that you’re seeing each 1/2 second? I’m seeing values that average 4mR/hr, with a few as high as 6.8mR/hr. Multiplying by 350 seems too good to be true for my setup and run parameters (best performance was at 40kV at 9mA, 14microns). This is with the hammer 1in from chamber body.
-Matt
-Matt
- Finn Hammer
Back in October I posted this picture of the Molybdenum kathode equipped feedthrough:
viewtopic.php?f=18&t=13936&p=92977#p92977
And since I have moved further with it, here is the description I promised.
First a couple of words about why I want to cool the kathode:
Running the kathode hot seems like a good idea. If you look at the 2 following pictures, the first one has a blue hue to it in a muddy atmosphere, and the kathode is still relatively cold:
On the other hand, in the following picture, the kathode has been red hot for a bit, and now the chamber appears to be clean:
However, when the power level rises beyond some 2kW, the kathode gets so hot that the fusor gets almost impossible to control. I assume that the kathode starts to emit electrons which recombine with the deuterons, and this accounts for the wild fluctuations in pressure, and the associated current draw, whatever, this situation has to be adressed, and cooling the kathode seems like a, -well, I just wanted to try it out.
Most of the feedthrough is, although flashy to the casual eye, just simple compression fittings disguised as field control toroids.
It is the internals that matter.
Here is a closeup of the first iteration:
As you can see, the cooling airflow in the center tube, is brought up close to the kathode, and reverses in the "sponge" like endplug, where it returns to the outside through the bigger pipe, both copper. The kathode is screwed into the "sponge" with a 6mm thread, and all this works well.
However, this feedthrough, with these dimensions is limited to 40kV by arching from the 12mm copper tube to the 19mm internal diametre of the quartz tube.
This led me to rev. Mkll, which looks like this, the one I am using now:
As you see, by adding length to the molybdenum stalk between the kathode cylinder and the sponge, I gain an increase in clearance by almost 100%, from 3.5mm to 6.5mm.
This has increased the stand off voltage to 75kV.
But it has also decreased the ability to cool the cylinder of the kathode, which has become even more desirable, since the increased voltage has also enabled a drastic increase in input power.
There appears to be 2 possible paths away from this blind alley, one is to increase the diametre of the glass tube to, say, 32mm internal. this would allow me to return to the previous kathode/stalk configuration, with now 10mm clearance, and this should then extend the voltage standoff towards, or even slightly beyond the magic 100kV.
Another option is to ditch the glass tubing, and switch to Macor. A suitable Macor slug is up and around 300$, so for now, I will stick to glass.
Trying to determine the voltage standoff properties from a theoretical point of view has not been an easy task. I see mention of the works of a certain gentleman named Mr. Paschen in this context, and even smirky comments like: "Now, there is Paschens law to you, my friend"
Is that really so? Can we use Paschens law at micron levels? I find that hard, with pd products between 0.01 to 0.03 torrcentimetres, from my view we are way off the chart to the left:
I know there is radiation, heat and all sort of stuff going on to confuse matters, but:
Perhaps Maciek Szymanski found the right passage in the right publication, when,
in this thread:
viewtopic.php?f=25&t=13111#p85254
in this thread:
he wrote:
Cheers, Finn HammerMaciek Szymanski wrote: ↑Sat Dec 14, 2019 5:03 pm Snip.
For the other hand the statement of L. Loeb Form almost 100 years ago seems to be still true, as the glow discharge is no longer a fashionable research subject:
About this region which lies in general below the pressure of the minimum sparking potential, ranging from 10e-5 up to 10e-1 mm of pressure, very little is known. Leonard B. Loeb “Fundamental Processes of Electrical Discharge in Gases” John Wiley & Sons, New York 1939, p. 476.
You mention once the cathode gets really hot around 2KW it become impossible to control. This is the famous electron runaway. Your cathode is becoming a heavy electron source that can runaway as the current wants to go through the roof. Thermal based electron emission coupled with high field emission will be a runaway condition. Solution: Instantly back off gas pressure and or the voltage. This will reduce the current and allow the cathode to drop back to a thermal level of comfortable electron emission and reduce the field. We are always at the edge of arc break down in out gas glow lamp (fusor). While not the classic hot arc, electron runaway precedes the arc condition. To take this to true arc you would need a power supply capable of many amps. Long before arcing occurs in our fusors the cathode would melt or the typically weak high impedance fusor supply would fail.
Wall or target loading can under electron runaway feed this condition with a sudden rise in gas pressure as the electrons emitted by the cathode slam into the target/walls releasing significant amounts of deuterium/deuterons which add to the current load.
I have discussed this state rather constantly in posts and Some FAQs since 2000.
We all find that peak of operation where this happens. You have found yours. So much of this runaway is related to grid construction and the chamber design. High field emission points are to be avoided. Sharp right angles facing the grid anywhere within the chamber or sharp angles in the cylinder grid ends or very fine wires in a spherical grid will set the limits in most situations where power applied forces the high fields to run away.
Even with no sharp or field emission points in a well designed fusor, thermal grid electron emission and wall unloading will still set a limit.
As for muddy vs. clean in the view port. when I see no glow in a clean, clear field with the grid at some high temperature and beaming flawlessly clean, I know I am at or very near an optimum operational point and am very close to possible runaway. I tread very softly to boost operation from this point. I never add more gas at this point just slow increases of voltage while watching the current like hawk! Increasing the voltage here increases the current by as little as .5ma. I make sure the current remains constant or falls back a bit. I can only then inch the voltage up. If the current starts to rise I see it rise very slowly and then back off. If it does not, but increases ever rapidly, I am at the runaway operating point.
