Demo Fusor Progression
Jim Enright
Real name: Jim Enright
Post by Jim Enright »
My son and I had spent time over the Summer building a demo fusor, mostly following the Make Magazine plans, and we were admitted to the Plasma Club. But we didn't want to end there so we had started thinking about constructing a similar set up using a stainless steel tee. Although we eventually want to build a fully functioning fusor, we are taking small steps trying to learn all we can along the way. We have gathered some of the 2.75" stainless steel conflat parts (which also includes a 6-way cross that we are intending to use for the fusor). The inner grid is 1/2" in diameter and made of 1mm stainless steel (although I think we will make it of 1mm tungsten wire, which is shown in the picture). For now, we will continue using the 15kV NST, variac, and Yellow Jacket 2-stage 8 CFM vacuum pump for the stainless steel vacuum chamber (the pictures of the electronics are from the demo fusor made with the borosilicate glass cylinder but I'm including the pictures to show those items). To seal the flanges, we are using viton gaskets. One of our current challenges is metering but we have followed information available in the FAQ's, purchased some gauges, and will be looking to get started on that part of the project soon. Although we do not necessarily need a full metering system for a demo fusor, it will help us to better understand the plasma in our chamber, and start collecting data. I am attaching pictures of some of the parts we have started gathering, and will provide updates as we progress. We are hoping to have the stainless steel vacuum chamber running in the upcoming week.
“Whether you think you can, or you think you can't — you're right." Henry Ford
Re: Demo Fusor Progression
Good work! Knowing what the pressure, voltage and currents are will teach you all about the behaviors of visible plasmas and how to control them.
Real name: Dennis Brown
Post by Dennis P Brown »
Get those instruments up and runningwith a plasma and then re-apply (the old list was purged to reflect the higher requirements now) for the new posting for the Plasma Club.
Real name: Mark Rowley
Post by Mark Rowley »
Nice to see all those conflat fittings and gauges! You guys are definitely starting off on the right path.
Return to “Images du Jour”
