Fusor Build - Colin Heath
Posted: Sun Jun 23, 2019 7:25 am
by Colin Heath
Hello All,
My third Fusor build (after many years away) in now in progress.
The main chamber is to be a 6” cylinder with Dairy clamp fittings on the ends to seal (A KF fitting but with O Ring groove). These will be sealed with Viton seals.
There will then be 4 off 1.5” inlets around circumference for vacuum, high voltage, view port and one spare for Gas later which will be vacuum gauge to start.
Here are pictures of the tube clamp I made this morningand the components for the stainless inner grid to be welded this week.
- IMG_2103 (1).jpg (74.49 KiB) Viewed 9614 times
- IMG_2102 (1).jpg (76.57 KiB) Viewed 9614 times
- IMG_2101.jpg (102.92 KiB) Viewed 9615 times
Re: Fusor Build - Colin Heath
Posted: Sun Jun 23, 2019 3:10 pm
CNC metal cutter.....me like.
Posted: Sun Jun 23, 2019 3:20 pm
by Colin Heath
Yes it has transformed how we fabricate and design day to day, would struggle without it now!
Posted: Mon Jun 24, 2019 12:57 pm
by Colin Heath
I managed to get the inner grid welded today between jobs.
Not sure if the edges will need sharpening to reduce collision with the gris but will find out in due course. This is the first of many different shapes I will no doubt try.
- IMG_2105.jpg (70.14 KiB) Viewed 9399 times
Posted: Mon Jan 25, 2021 12:06 pm
by Colin Heath
Thought I should post up some progress as it’s been 1.5 years!
Got the chamber welded up today, using all dairy clamp fittings as these are same as KF but with self aligning seals.
It has 2 off 6” blank plates which one of will become a view port I am making and the other will be to house extra things later if required.
There are also 2 off 1.5” and 2 off 2” inlets.
Also have acquired an edwards 2 stage pump to get started.
Posted: Mon Jan 25, 2021 12:35 pm
Great looking piece of work. Glad to see you back and looking forward to future reports on your effort.
Posted: Mon Jan 25, 2021 1:15 pm
by Colin Heath
Thanks Richard,
It has niggled me for years that each time I have built a system, I have then stopped before producing neutrons.
Want to make sure I don’t sell this one and also do lots of other interesting projects in vacuum.
Posted: Tue Jan 26, 2021 5:03 am
by Dennis P Brown
Well, then you have a clear path - neutron detection. Such a goal is, without a dought, the best objective to obtain relative to plasma research/experiment; neutrons are elusive and very difficult to detect particles - further, thermo-nuclear fusion is one of the very few ways* for any amature to generate large numebers of neutrons. So proving fusion via neutron detection is a double achievement in that regards.
Even better there is a community forum (thanks to the hard work of a few indiveduals here!) that provides a place that one can gain adminstion to the very special and select group of people that have achieved fusion via neutron detection. So finishing your project is well worth the time and effort; especially if one already has both the deuterium supply and required power supply (as well as a chamber as your pic shows.) Best of luck and stay with it.
*Besides a very special person that has managed to do ehanced fission; which is not possible here forobvious reasons
Posted: Wed Jan 27, 2021 3:35 pm
by Colin Heath
Thanks Dennis, yes I want to see this one right through and looking forward to the challenges ahead.
