Say hello to my little (HV) friends
John Myers
Re: Say hello to my little (HV) friends
Post by John Myers » Thu Nov 09, 2017 3:38 am
The HTR and RES pins were both a little bent. Luckily the vent port wasn't bent or the D2 magic could have leaked out. The device is heavy so I think people picking it up would end up pressing against the pins causing them to bend.
Roberto Ferrari
Real name: Roberto Ferrari
Post by Roberto Ferrari » Thu Nov 09, 2017 2:42 pm
John
A crack in any of the ceramic-metal seals would impair the hermeticity.
John Myers
Post by John Myers » Thu Nov 09, 2017 4:53 pm
That's good point. I was thinking along the lines of the vent tube being punctured/cracked.
The 'pins' you see are more of a terminal block that fit over the actual pin and have a set screw to attach to the pin. I'll remove it tonight and do a closer inspection.
John Myers
Post by John Myers » Sun Nov 12, 2017 3:17 am
The thyratron had a little ceramic chipped away by the pins but it doesn't look deep enough to be a problem.
I got this Xray transformer earlier in the year off of Craigslist. The dentist even gave it to me for free when I told her it was for my electronics hobby.
I don't see any voltage/current specs. Does anyone have an educated guess in what they might be?
John Myers
Post by John Myers » Mon Nov 13, 2017 2:52 am
The inside of the spark gap transformer only had a transformer in it. It was already drained of oil.
I suppose the instructions on the case were for whatever system/unit it was part of.
Inside of spark Gap Transformer
